nvh 3500 Need Help! - Hemi Truck Club
Old 08-15-2014, 08:44 PM   #1
nvh 3500 Need Help!
Hey guys quick question I've got a 2003 dodge ram 1500 with a 4.7 motor and nvh 3500 transmission, 5 speed manual. I wanna drop 5.7 in it but not sure if the 5.7 will bolt right up to my tranny. Does any one have any info for this set up ?
5.7hemiman is offline   Reply With Quote
Old 08-15-2014, 10:22 PM   #2
Should bolt up they run it behind the 2500 5.7 hemi's I'm sure there's something that will need to be bought or changed a little bit.
Old 08-16-2014, 05:45 AM   #3
preachp's Avatar
Hi 5.7hemiman,
I would think you just need a bell housing that fits the tranny and the 5.7. I can't see Chrysler spending the money on tooling to have hemi's having different bolt patterns on the block when it is much cheaper and easier to use a universal pattern on the block and change the pattern on the other side of the bell housing to fit the various trannies.
preachp
Acts 1:11 Which also said, Ye men of Galilee, why stand ye gazing up into heaven? this same Jesus, which is taken up from you into heaven, shall so come in like manner as ye have seen him go into heaven.
preachp is offline   Reply With Quote
Old 08-16-2014, 09:28 AM   #4
5.7hemiman
Old 08-16-2014, 09:48 AM   #5
Bell housing should be the same the 545 is bolted to 4.7/5.7 both so manual trans will likely bolt right up. The clutch and flywheel will
Likely be diff
Old 08-16-2014, 10:49 AM   #6
Thanks yal
Old 08-16-2014, 11:58 AM   #7
Matt
MANual_puller's Avatar
I can't think of any reason that the engine and transmission wouldn't physically bolt right together without any problems. The internal mating shouldn't be too tough either but I don't think Chrysler ever built a hemi mated with the nv3500, could be wrong though. The 2500 rams had the nv4500, nv5600, and G56 manuals in that order by years(unsure of exact splits). I think the nv3500 was strictly 4.7L and the 545 auto came with either engine in 1500 Rams. If the clutch from your truck will bolt on to a 5.7L flywheel you are golden. Worst that happens to get it done you have the flywheel drilled and tapped to accept the clutch plate. Most machine shops can handle that. Good luck and keep us posted!
Old 08-18-2014, 12:50 PM   #8
5SpeedHemi's Avatar
I have a 03 Ram 2500 and it has a NV 4500 pretty sure the NV 3500 came with the Ram 4.7 3.7
Old 08-18-2014, 01:12 PM   #9
Matt
they should still bolt together though and if you leave the hemi stock it should be alright. I wouldn't go too power crazy without also upgrading to th,e nv4500 too.
Old 08-18-2014, 08:48 PM   #10
Yal know any where I can find an nv4500 that's not gonna break the piggy bank I've got a 5.7 in the garage just no tranny. Time for the 4.7 to retire and let big boy come to work but gonna have to retire the 3500 as well. I appreciate yals comments.
