No run dodge - Hemi Truck Club
Old 06-08-2016, 04:22 PM   #1
No run dodge
I have a 2005 Dodge Ram 1500, 5.7 liter, 4x4, quadcab, shortbed. I have had the truck parked for almost 2 years due to a mechanical problem. My wife was driving it and it died on her, she got it to restart and drove it home and then cut it off to come back out and find it would not run.
The truck will start and run for a few seconds then die. It is not throwing any codes and has good fuel pressure in the rails. I have replaced to following parts.
Crank sensor
Cam sensor
Evap canister
Throttle body
Fuel pump was less than a year old.
Coolant sensor
ECM
Unbolted the catalytic convertors think it was back pressure
New battery
Tested the alternator
I still have an oil pressure sensor for it.
I was told it could be the transmission. Maybe the wcm. Can anyone hep in this problem. I really need my truck back.
paramedicrescue1056 is offline   Reply With Quote
Old 06-08-2016, 04:51 PM   #2
Can you pull the spark plugs keeping them in order and take a picture of them to see what conditions are in each cylinders. Does the fuel pump cycle when the ignition is turned on?
Old 06-08-2016, 05:11 PM   #3
How would I tell about the fuel pump?
Old 06-08-2016, 05:23 PM   #4
Take the gas cap off and while listening have someone turn the ignition on. It should run for about 3-4 seconds. then shut off. This is controlled by the ASD relay.
Old 06-08-2016, 05:36 PM   #5
I dont hear the fuel pump but I have pressure
Old 06-08-2016, 05:40 PM   #6
How do you test for fuel pressure? With your ear close to the fuel tank fill opening, the pump running should be obvious.
Old 06-08-2016, 05:45 PM   #7
I cant hear it real good outside but I can hear the fuel pump click on in the cab.
Old 06-08-2016, 05:46 PM   #8
I had a mechanic friend come up. He put a pressure gauge on it. It was around 54 psi when cranking and then went to 35 at idle.
Old 06-08-2016, 05:52 PM   #9
Ok, now we have something. The 05 regulator is set for 58 psi At idle it should be still 58 or very close to it. Driving hard you might see 56psi. The stock pump is loud enough to hear at the fill tube opening. If you use a piece of heater hose it will be quite loud.
Old 06-08-2016, 05:55 PM   #10
https://youtu.be/Bizz_1I2BoE
This is a video of the truck starting, first start is me not touching the gas, second is me tlgiving it gas.
