Newly rebuilt engine making noise - Hemi Truck Club
Old 01-28-2014, 09:31 AM   #1
Gold-Member
kcd1369's Avatar
OK. I figured instead of continuing to hijack the thread we were on talkin about this, I would move it to where it belongs.
Here is an audio clip of the noise my engine is making when started first thing in the morning. It goes away after about 5 minutes. I have not been able to record the noise at different RPM's since when I leave there is no one around with me.
If anyone has an idea as to what it could be please chime in.
The engine has about 800 miles on it at this time since the rebuild. The oil level and pressure are fine. There are no other issues with it besides the noise.
Old 01-28-2014, 09:36 AM   #2
That's sounds deep to loud to be slap
Likely a lifter issue especially if its going away after a few mins anything else would happen all the time constantly one of the lifters likely bleeds down over night and its just filling back up I the am needs to be checked tough for sure
Old 01-28-2014, 09:39 AM   #3
Gold-Member
kcd1369's Avatar
That blows. I don't think they changed the lifters on the rebuild. So I guest that would not be covered in their warranty.
Old 01-28-2014, 09:42 AM   #4
Gold-Member
kcd1369's Avatar
I was wrong. They did put in new lifters. So Keith, is this serious? And time consuming? I would guess the head would need to come off to check that right?
Old 01-28-2014, 04:53 PM   #5
Yes heads would Deff need to come off for sure they cover lifters
Question if you run truck for 5 minutes noise goes away?
If you shut off for say an hour of shopping does it come back on restart?
Also in that first 5 mins in AM when noisy if held at say 1500-2000 rpm is it noisy?
Old 01-28-2014, 07:32 PM   #6
Take a long screw driver to listen and locate where the noise is coming from. Check the whole engine David.
Old 01-28-2014, 08:38 PM   #7
What oil did you put in the engine(5w20 non synthetic). It doesn't sound like a steady noise? Before you pull the heads, check to see it the push rods are in their correct position on the rockers and lifter seats.
Old 01-28-2014, 09:26 PM   #8
Gold-Member
kcd1369's Avatar
Stu, yes I put the originally specified oil in. Not sure right now. But the same weight and manufacturer that Dodge recommends.
Kieth, when its cold and I rev it to around 2000rpm it seems to go away. And I checked today. Every time it sits for a few hours, when I start it the noise is back then goes away.
I looked at my warranty papers today and it says if they didn't take it out originally, then it will need to be brought back to them the same way for warranty work. How jacked up is that?
Old 01-28-2014, 09:45 PM   #9
Warranty work.
Old 01-29-2014, 05:03 AM   #10
They need to hear that noise for themselves
If it goes away when reved its usually a deep eng noise Pin/bearing
Bring the truck by the builders and have them listen to it
