New spider gears and clutch pack Dana 60 issue!? - Hemi Truck Club
Old 12-29-2017, 08:45 AM   #1
Randall
BeeFast's Avatar
So I just put new spiders and clutch packs in my Dana 60. Itís so tight that it literally takes two grown men on both axels with bars to make it slip or rotate against each other. Spins freely as a posi unit just not a LSD. Is that normal or have I screwed something up???
Procharged P1Sc, Big valve P&P heads,HC lifters,Inertia Blower cam, Mopar long tubes with SS 3"true duals, Magnaflow hi-flow cats & Race mufflers, T56 manual swap with Centerforce DYAD clutch, Dana 60 with cryoed 4.56 gears, Caltracs, Flexalite & custom Injected Engineering dyno tune.
BeeFast is offline   Reply With Quote
Old 12-29-2017, 10:09 AM   #2
ric3xrt's Avatar
Nope, it's fine.
04 GTX...Under the Knife.
Old 12-29-2017, 10:31 AM   #3
Randall
BeeFast's Avatar
Originally Posted by ric3xrt View Post
Nope, it's fine.
Thanks. I take it, once itís under the truck and after a break in period, it loosen up?
Old 12-29-2017, 10:41 AM   #4
ric3xrt's Avatar
Yep, once you get the full body weight of the truck on it, it will act like it should, remember your two guys is only 400-500 lbs or force and your truck is about 4500 lbs of force. after 4-5 years you'll be one legging it once in awhile and think , dam it I have to rebuild it.
Old 12-29-2017, 08:31 PM   #5
Randall
BeeFast's Avatar
Thanks for the input!
