Motive 4.56 gears with stock rear end - Hemi Truck Club
Old 06-07-2011, 05:04 PM   #1
prod646's Avatar
I had to spend the money saved for gears on tires so, back to square one. As I save again for gears, a question. When I get the Motive 4.56 gears, will I be fine with my stock limited slip differential??
prod646 is offline   Reply With Quote
Old 06-07-2011, 09:00 PM   #2
You can use it no issues there the only problem will be that you will be more likely to spin one tire with higher ratio check moesperformance thTs where I got mine as a kit with a Detroit true trac locker not sure on current prices
Old 06-08-2011, 05:54 PM   #3
You should still spin both considering you have the oem lsd. Maybe remove the retainer clips or check them to make sure they are good.
That said i would consider upgrading to a aftermarket piece and you can do both at the same time.
I have been through two gears changes w/ my oem lsd and still going good but i would like to go with a aftermarket locker very soon.
Somehow some other mod pops up LOL.
