LSD Clips wore into cap/Housing and True trac and Auburn ? - Hemi Truck Club
Old 09-27-2015, 08:10 AM   #1
My Caps, and housing look like this, Post # 419 and #422 , all of the diff shops I spoke with said that it should be fine to run like this what do you think?
http://www.dodgetalk.com/forums/show...&pp=40&page=11
( These are not my pic's but look just like mine.)
I ordered a Richmond master rebuild kit and a Detroit True Trac Diff to replace everything, Ring and Pinion look fine.
Any am worried about the housing and cap staying together.
Any tips on set up or better yet do you have a guide?
Thank you so much.
P.S I have a 3.92 ratio. Thank you for the info, Now if I can figure out how to print just the Rear axle rebuild part of the manual.
Old 09-27-2015, 08:35 AM   #2
Gold-Member
kcd1369's Avatar
to HTC.
Couldn't open the link.
Old 09-27-2015, 08:45 AM   #3
Another Broken C Clip Poll "year" - Page 11 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Try this Thanks
Old 09-27-2015, 10:22 AM   #4
Welcome to the forum. I haven't had this happen, but while talking with a Chrysler mechanic who specialized in doing differentials told me when these came in the official response is the housing needs to be replaced. However he added often he would use salvage yard caps and it was a good repair. The caps are suppose to be fitted individually to each axle. But production is so close often the will fit without issue. As for the DTT I have used one for a few years and it continues to run without issues. Good luck..
Old 09-27-2015, 03:04 PM   #5
The housing is gouged also, This is the first time Iv heard to replace. I have access to a junk housing that has a good Cap.
Old 09-27-2015, 03:14 PM   #6
If it was me, I would purchase a complete open carrier differential from another truck, then rebuild it with the new parts, including a motion 4:56 gear set.
Old 09-27-2015, 03:48 PM   #7
Like I said, officially not recommended, but has been done.
Old 09-27-2015, 03:54 PM   #8
If the main diff housing only has minor nicks then reuse it. As for the housing cor the ring gear change it all out to the true Trac and be done with it. Have fun mine for years issue free so far
Old 09-27-2015, 05:08 PM   #9
ABSOLUTELY
Don't waste your time with crap - go directly to the Detroit Tru-Trac and Motive 4:56 gears and be done with it forever .
Old 09-27-2015, 10:41 PM   #10
