Help! I just ruined my transmission!! - Hemi Truck Club
Old 11-03-2014, 11:18 AM   #1
RAMjet's Avatar
How're you doing Folks!! I believe I just ruined my truck's tranny... A copuple of years I installed 37" tires and kept it going like that until last year when I installed new ring and pinions on both differentials... I believe I did that too late... A couple of weeks ago while messing around (speeding ) I got an engine light. Later, I plugged in a scanner and showed fault code P0732... I checked and replaced the easiest things... solenoids, filters, fluids... and no luck so far... I don't know if buying a master kit to rebuild the transmission or to get a refurbished one... The big question is I'm not sure what model my tranny is? a 45RFE or a 545RFE. All your inputs are highly appreciated! Cheers!!
FYI, my trucks VIN 3D7KS28D27G823675
07 RAM 2500 SLT, CUSTOMIZED BORLA EXHAUST SYS, COMPLETE RANCHO LIFT KIT, 37" PRO COMP A/T KM2, FRONT & REAR EATON-DETROIT TRUETRAC POSI & 4.56 GEARS
RAMjet is offline   Reply With Quote
Old 11-03-2014, 11:55 AM   #2
Being a 07 it'll be a 545RFE.
Old 11-03-2014, 12:27 PM   #3
45rfe and 545rfe internally are the same it's the PCM programming that's diff.
Rebuild it if you can or have a shop do it or buy another new/used trans. Your a little far away for me to rebuild it lol! I feel your pain a broke trans sucks (13 here).
Old 01-13-2015, 10:02 AM   #4
How's the fluid level? I'm guessing you refilled it when you changed the filters...if it's a little low it could cause this. Just being hopeful for the cheap fix before you get a new trans
2006 Ram 1500 QC 4x4 5.7 Hemi: 132,xxx miles
Mods: 1-ton trans cooler | 3" FM 40 single exhaust
89gtcs is offline   Reply With Quote
