Got a shifting issue (non hemi related) - Hemi Truck Club
Old 04-09-2017, 07:06 PM   #1
pri_i_oh's Avatar
Ok guys its not a hemi but its still a mopar. Common saying in my house "mopar or no car"...lol
I got a 2004 jeep grand cherokee 4.0 that has a slight shifting issue. For some reason periodically when it goed to shift into the highest gear it either shifts real hard or it wont shift at all and just winds out. Im having a problem pin pointing it because i cant get it to do it to me. It happened to a buddy of mine when he drove it (i was in the passenger seat) and it happened to my wife today. If i remember correctly after talking to the dealer its a 42RE tranny.
Im thinking a couple possibilities:
1. Shift sensor
2. Governor
3. Theres a slight exhaust leak. Could it possibly be enough to not create enough back pressure and the PCM is saying "its not time to shift yet"?
Old 04-09-2017, 08:00 PM   #2
Matt
MANual_puller's Avatar
Is this what you got to replace the rango or you still have that? Your issue is a Jeep thing..... I don't understand
Old 04-09-2017, 08:12 PM   #3
pri_i_oh's Avatar
Lol....no we still have the rango. Surprisingly, no issues with it for a while. That will probably go up for sale later this year. The jeep is for my son
Old 04-09-2017, 09:20 PM   #4
Ok the 42re is the same as a 46rh that I have just weaker lol. I assume you mean OD is not kicking in sometimes. That entire unit is in the tailhousing. They are known for tearing the apply piston seal and intermitantly having OD. May need to tear this one down and have a look.
Old 04-09-2017, 09:23 PM   #5
pri_i_oh's Avatar
Well crap.....looks like im pulling tge tranny out huh?
Old 04-10-2017, 05:45 AM   #6
pri_i_oh's Avatar
Would I be better off finding a 46rh tranny?
Old 04-10-2017, 06:46 AM   #7
pri_i_oh's Avatar
Also, do i have to pull the tranny to get to the inner workings of that tail section?
Old 04-10-2017, 09:21 AM   #8
To get to the internals of the tailshaft no you don't you can pull that off in the truck. It can be rebuilt but will need the alignment tool on reassembly of the unit in order for the output shaft to go in correctly on the truck. There's two sections inside that have to be inline so it will slip onto shaft.
The 46rh is going to be longer that the RE so it won't work without a few other things like shafts and what not
Old 04-10-2017, 10:11 AM   #9
pri_i_oh's Avatar
Ok cool. I dont really have the fascilities for dropping a tranny. My wife just td me today that it did it to her in 2nd gear, not OD. So i think im just gonna start by replacing the solenoids. Then if it continues but only in OD ill know it has to do with that tail unit
Old 04-10-2017, 10:25 PM   #10
It may need a band adjustment only. It's on the side of the trans and it's very easy to do. Will need an inch pound torque wrench though
