Freaking out - Hemi Truck Club
Old 07-13-2015, 08:12 PM   #1
Freaking out
So I dropped my '14 1500 44 using mcgaughys 2-4 kit yesterday (I've had the kit for almost a year) to find out today they have had problems with premature failing C/V axles? Has anyone had this issue? Is there a fix?
Old 07-13-2015, 08:17 PM   #2
With a 2-4" kit the axles are failing? How excatly are the boots getting torn or they breaking somehow
Old 07-13-2015, 08:26 PM   #3
Mcgaughys didn't specifically say what part (s) have failed. There doesn't appear to be a angle issue that I can see. Especially if you take into consideration all the guys running lift kits....
Old 07-13-2015, 08:30 PM   #4
Then it really makes no sense to me that there would be an issue.
Old 07-13-2015, 08:59 PM   #5
That's what I'm saying. 2" is within normal suspension travel
Old 07-14-2015, 07:05 AM   #6
Enormous Member
Hugh Jassole's Avatar
maybe those things need a bit of an angle to keep from vibrating. Kind of like when your driveline angles are wrong and the driveshaft wants to vibrate ?
Or, they could now be a bit too long and binding up
My other truck is an R/T
Old 07-14-2015, 02:28 PM   #7
They are angled and cv joints aren't prone to vibration like u-joints. Binding shouldn't be an issue due to the inner being tripod joints.
Old 07-14-2015, 02:31 PM   #8
Mcgaughys just emailed back and said that it was an isolated event but to prevent future problems have since discontinued the kit for 44s. That sounds a bit fishy to me to discontinue a product after a single failure.....
Old 07-14-2015, 07:08 PM   #9
it was likely that owner took the issue to extreme with them. I woudnt worry about it if I were you. if it was that big an issue safety wise I would have thought they would offer a refund or something. its likely they just don't want a repeat of whatever went down with said customer.
Old 07-14-2015, 07:29 PM   #10
Good point didn't think about that. Could have had damage from outside influence too like an accident or something.
