Do I have Trac Lok? - Hemi Truck Club
Old 10-26-2011, 06:02 AM   #1
Of course my glovebox tag says DSA Anti-Spin, but how do I know for sure if I have Trac Lok or not so I can get the friction modifier?
I'm about to go to the dealer and see if I can get a build sheet, but any advice would be appreciated.
KenNN is offline   Reply With Quote
Old 10-26-2011, 06:02 AM   #2
Old 10-26-2011, 01:17 PM   #3
HemiByrd's Avatar
The Anti-Spin is a limited slip. You can add the friction modifier.
Old 10-31-2011, 05:19 AM   #4
The service manual says that the friction modifier should ONLY be added to the Trac Lok. How do I know definitively if I have the Trac Lok vs. the non-Trac Lok LSD?
Old 11-02-2011, 09:29 PM   #5
Trac Lok
Take the cover off and inspect the differential unit. Do you think it has been changed?
Old 01-07-2012, 03:29 PM   #6
NashvilleHemi's Avatar
Best way to tell... Do a burnout and see if theres 2 tire marks. If there is you got trac lock!!
04 QC SB, Dynomax cat-back, K&N 77 series CAI, Trick flow Underdrive Balencer, AFE TB spacer, MSD 8.5 wires, e3 plugs, Superchips 3865, 3rd Strike ported TB, Jet 180 T-stat
Old 01-07-2012, 03:53 PM   #7
This question is usually followed with "what gear ratio" do I have?
Put the rear axle on jack stands and mark the tire and drive shaft with chalk and turn the tire one complete turn and count the turns of the drive shaft. Need to block the off side tire for the count. If both tires turn in the same direction it has limited slip, if the tires turn opposite direction it is open. Or look in the glove box for a sticker or submit your VIN for the original build info. Of course just lighting them up is more fun...
