Differential cover - Hemi Truck Club
Old 07-21-2014, 05:19 PM   #1
Differential cover
Has anyone changed their differential cover to a larger custom type cover that holds more fluid? I have a Ram 1500 with the corporate differential with the 12 bolt cover. I tow a 26 ft. camper and would like to have some additional rear end fluid to help keeps things a little cooler. Does anybody know who sells the larger differential covers with cooling fins that fit a 1500?
KTSisk is offline   Reply With Quote
Old 07-21-2014, 05:43 PM   #2
David
ATXHEMI's Avatar
Moesperformance.com Matt is a stand up guy. And his shipping is very quick.
Old 07-21-2014, 06:05 PM   #3
Moes or thirdstrike have them for sure.
Old 07-21-2014, 06:13 PM   #4
MikeHTally's Avatar
PML cover here. Not sure where it came from
Old 07-21-2014, 07:05 PM   #5
Board of Directors-Bill
arocketman's Avatar
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 07-21-2014, 07:33 PM   #6
PML Polished Here
Bought it LONG AGO through what used to be our Hemi
Truck Club Store...
Old 07-22-2014, 08:55 AM   #7
TylerB's Avatar
Mag-Hytec here from Matt @Moe's Performance
TylerB is offline   Reply With Quote
Old 07-22-2014, 02:05 PM   #8
Pull Ya's Avatar
I have a Mag also.
Jay
Just cause it's loud don't make it fast & just cause it's shiney don't mean it's protected.
Pull Ya is offline   Reply With Quote
Old 07-22-2014, 03:21 PM   #9
Couple of questions, Has anyone found a low or high pressure point in the rearend housing that a hose could be attached that would flow oil through a cooler without using a pump? Thermo dynamics will move hotter oil up drawing cooler oil from below. I suspect there is too much turbulence inside the housing to allow this to naturally happening. Any ideas?
This is a trans cooler that I think would work for a rearend.
Old 07-24-2014, 05:57 PM   #10
Extreme Driveline Perf
Supershafts's Avatar
You could try it, and im sure you'll get some cooling from it, but the pump is the true better way.
Not to mention to get it to work the other way using the gears to do it would mean drilling and tapping areas you really might make a issue at.
As for covers...
AFE the best if you have a diff they cover, then Mag-hytec and then the rest
