diff noob need of help - Hemi Truck Club
Old 05-13-2015, 11:45 PM   #1
HemiRat's Avatar
Im look into getting 4:10 ring and pinion gear set from moes performance, after i lost to a friend with the same truck with 3:92 gears compared to my 3:55 gear. The problem if i get to 4:10 kit installed will it still have a factory lsd in it. Unfortunatly im not very knowledgable about differentials. Any help would be apreciated.
HemiRat is offline   Reply With Quote
Old 05-14-2015, 12:36 AM   #2
Yes you can keep the LSD your only changing the gear itself.
Old 05-14-2015, 02:58 AM   #3
Board of Directors-Bill
arocketman's Avatar
Nice little MOD for sure.
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 05-14-2015, 06:26 AM   #4
James
DakotaJ's Avatar
4.56's would definitely put you in front of your friend.
Old 05-14-2015, 08:16 AM   #5
Exclamation
...for all of the trouble and expense I would also go 4:56 .
Old 05-14-2015, 09:23 AM   #6
HemiRat's Avatar
Thanks guys, i thought about 4.56 gears but i still do drive the truck everyday. And use the highway often so i dont wanna get to carried away
Old 05-14-2015, 10:02 AM   #7
What speeds do you drive normally? How tall are your tires?
Don't fear the gear!
Old 05-14-2015, 10:51 AM   #8
HemiRat's Avatar
Speeds normally around 60 to 80 kmph but ocasionally 100kmph. The tire is a 275/45/r20
Old 05-14-2015, 11:00 AM   #9
john
i been thanking of doing the 4.10 myself it will as increase your pulling power
Old 05-14-2015, 11:29 AM   #10
100KPH is 63mph and your tire's if not a typo about 30" stock would be 33". With the speeds you run at I would definitely recommend 4:56. It would give you a real improvement in acceleration and something around 2200 rpm at speed. I run short 28" tires and a 4:10 gear and at 65mph I'm turning 2150 rpm. My wife's Endeavor is stock and turns higher rpm than my truck. You will most likely see an improvement in mileage with the short gear running in the hemi's sweet spot if you can stay out of the throttle. Good luck...
