D60(srt10) swap pics - Hemi Truck Club
Old 11-23-2008, 08:42 PM   #1
Alright guys and gals i will eventually make a complete how to on this one but for now i wanted to share the photos with you and give you the basic requirements i did this all in a one "CAR" garage on jackstands lol. Yes it is possible to do this, there is some things differently you must do but dont be intimidated. Since i have the mcgaughys 2/4 drop i had to shorten my driveshaft compliments of AUSTIN DRIVETRAIN (they do the best damn job), 1" which gave me enough space for dips and bumps to prevent a cracked tailhousing on the transmission and still be in a comfortable zone as far as yoke slip and output shaft go. The leafs bolt up under the axel so this works great for dropped trucks, if not im sure you could cut your stock perches and weld them ontop of this axel but that requires some more work. The D60 has a pinion yoke instead of a flange so the stock driveshaft flange has to go, and the u joint is different as well. I got what we call a Bastard joint with two bearing cap sizes one for our 1330 series drivelines and one for the 1350 SRT-10 series driveline you can get that part here http://cgi.ebay.com/ebaymotors/Dana-Spicer-5-648X-U-Joi...891197QQcmdZViewItem if not just search the 1330 to 1350 conversion joint. I went ahead and bought two new girdles and 4 bolts for them at dodge that hold the u joint onto the pinion yoke. The axel i bought came with brakes but if you need hemi brakes on them you can buy brackets to mount stock calipers onto the axel.If you have questions feel free to ask me, here are the pics.
[IMG]
http://i21.photobucket.com/albums/b269/Patman03SprCrw/Q...0/DSC05921.jpg[/IMG]
Yep my pinion seal is leaking lol Mine also looks bigger because it is on jackstands so dont be fooled.
WIMPY!!!
BEEFY!!!!!!
This is what happends with too much wheel hop and a flip kit.
D60 perches
conversion joint
My cammed hemi
http://www.youtube.com/watch?v=hw1lDSLSKgc
JOHNNYHEMI
Stu cam 218/218 112LSA spartan max, 6.1 rods, 6.1 springs,Tuned, Hedman Longtubes, Dual 3" dynomax bullets, NO cats, SRT-10 rear axel swap
D-60 LSD,4.10 gears srt-10 dual piston vented rear brakes
SHARADON STAGE III VALVEBODY, Lincoln 18" E-Fan,TransgoHDReprogram SHift Kit with resistor, Taylor Shorties,mcgaughys 2/4 drop, Custom painted bumpers, shaved and painted grille shell, rumble bee grille inserts, Debadged,
Old 11-23-2008, 08:42 PM   #2
[IMG]
WIMPY!!!
BEEFY!!!!!!
D60 perches
conversion joint
My cammed hemi
JOHNNYHEMI
Old 11-23-2008, 09:29 PM   #3
madcat's Avatar
Nice
__________________________________________________ __________________________
06'-Ram-Hemi-Pearl Black-112 Spartan Cam-HHP/BES Stage 3 CNC Heads-Long Tubes-4.56 gears-Magnaflow-AEM CAI-Wideband-Diablo Dyno Tuned By XPSolutions-TCM tunes and PCM tweaks made WILD by Whitelighting 152,000 miles, 2nd trans (8.20s 1/8th, street weight, stock stall, on slicks)
06'-Magnum R/T-Hemi-Pearl Black-Diablo Tune-Magnaflow (8.80s, with the car seats)
02'-Yukon XL-2500-4x4-Prius Eating Gas Guzzling-Work Truck
http://youtu.be/jgAWnaRLfv8
"Those who hammer their guns into plows will plow for those who do not.." Thomas Jefferson
Old 11-24-2008, 01:55 AM   #4
Old 11-24-2008, 04:18 AM   #5
brand_x_racing's Avatar
SO DID THE VIPER BRAKES MAKE A DIFFERENCE??? FEEL ANY DIFFERENT TO YOU DRIVING IT? GOOD JOB BRO!!!
2011 Dodge Ram CC hemi mineral grey, 22 KMC slides
1956 Dodge c3 pickup, 1/2 ton , 318, disc brake conversion, 904 trans, 791 rear axle, 15 gallon schlitz keg for gas and mini Full custom audio system, 1960 Cushmas Eagle, full chopper, 16hp v-twin, raked to 40 degrees, custom cut fenders and alum accessories, custom silver with blue flames. 1954 Buick Super 4dr Lido green and white, nailhead powered, 1941 Chevy fenderless truck project, 1958 ford fairlane 5.0 powered,
www.stubbsrodandcustom.com
"Hey where da white women at"
Old 11-24-2008, 04:53 AM   #6
zwa21's Avatar
Flowmaster Super 40
Old 11-24-2008, 05:14 AM   #7
Good job.
HTC.com Titan Killer Club
Member # 17
Old 11-24-2008, 06:06 AM   #8
04LaramieQC's Avatar
Nice! Those red SRT calipers are going to look awesome behind your rims.
_____________
2004 QC 2WD
Comp 268 cam, 6.1L valvesprings/pushrods, Pacesetter Jet-Hot coated LT's/ORY, K&N intake, Taylor shorties, Flowmaster 40 dumped, 3.92/posi rear, SCT tune by Hemifever
04LaramieQC is offline   Reply With Quote
Old 11-24-2008, 07:30 AM   #9
07hemisport's Avatar
Great pics. I am doing the swap in a few weeks so I look forward to your writeup. I completely rebuilt and detailed my axle while it it out. Also installed a set of 4:56's.
SRT10 undersprung rear axle with 4:56 gears, Mcgaughy's 2" drop spindles and Belltech 2" drop coils, supermaxx longtube headers and hi perf cats, Edge Evolution gauge pack, Fiberglass hood with functional shaker ram air, and Airaid CAI, 180 Jet stat
Flexalite E fan, Diablo tuner
22'S WITH 305"S all 4 corners
Hurst Roll Control
SRT10 rear sway bar
07hemisport is offline   Reply With Quote
Old 11-24-2008, 08:10 PM   #10
Actually yes the brakes did make a noticeable difference, you dont really pay attention to rear brakes but i immediately felt the difference, of course it could also be the new fluid, because you can plan on draining the system after you take those lines off. I bled the whole system and put in brand new fluid. I can definitely help you out with that install when you have questions, if you are "mechanically inclined" this should be easy, I started at 7:30 with a buddy with the wheels on the truck and had the new one on with wheels in about 2.5 hours, of course it wasnt driveable until i had my driveshaft reworked. I also plan on welding in a bracket for the Wheel hop Damper ontop of the diff and putting on the rear sway bar from an srt10.
My cammed hemi
JOHNNYHEMI
