D-Day - Hemi Truck Club
Old 03-03-2012, 07:59 AM   #1
Blkram88's Avatar
After having to look at my gears sitting in a box in my closet for way too long my installer finally gave me a date for us to install them!!! D-Day is set for 3-7-12. Im so pumped, just cant wait. Hes gunna setup the rear while I pull the front diff and hopefully we can get it done in one night, and theyll be broken in for spring time!
Performance Mods: Custom CAI, Power wire, Heddmen LT's, Cat delete, Dynojet Wideband 2 A/F Gauge, Custom Bent 2.50" Full Exhaust Into A Dynomax Ultra Flo X Muffler Dumped Before The Rear Axle, NGK 4306 plugs, Taylor '409' 10.4mm race wires, Circle D 2800-3000 Stall Converter, Sonnax Line Booster, 1 Ton Tranny Cooler, Motive 4.56 Gears, Comp cams 268 cam, 6.1L pushrods, 6.1L exhaust valve springs, SCT custom tune.
Wish List: Comp Custom Cam, 85mm TB, Milled And Worked Heads, Bored 40 Over(If Motor Ever Lets Go,) StageIII Valve Body, E Fan(Waiting For Install)
Blkram88 is offline   Reply With Quote
Old 03-03-2012, 07:59 AM   #2
Blkram88's Avatar
Old 03-03-2012, 08:02 AM   #3
HemiByrd's Avatar
You'll love the gears.
Old 03-03-2012, 09:44 AM   #4
HTC.com Titan Killer Club
Member # 17
Old 03-04-2012, 03:38 PM   #5
Blkram88's Avatar
Ive heard nothing but good things about the gears, im really hoping it puts me into the mid 13 range on my 1/4 mile and I know ill be in the 8's in the 8th mile
Old 03-13-2012, 09:16 AM   #6
Old 04-02-2012, 02:43 PM   #7
Blkram88's Avatar
Ok update on the install, sorry but ive been so busy with work and this install. First night we got the front swapped out, done, and it looked like we could finish tomorrow or even that night if we pulled all nighters. Then came the rear end, as we tore into that we found the LSD clucth clips were everywhere, pieces and fragments were covering the magnet and 2 broke inhalf and wedged themselves in the carrier and cut a nasty groove into the right side of the cap and housing. The pieces of clips destored the carrier so I ordered a detroit trutrac LSD and had to wait 2 days until that got here. When that showed up we hustled to get it back together and in the process forgot all about switching over the toner ring so we get it all back together and go for a test ride to find the speedo didnt work so put it back on the hoist and called it a night. The next night I tore it back apart and switched the toner ring and threw it back together and reset it up, went throught the brake in period and finally got to see what the gears did for Cam (trucks name lol.) All in all the gears are a nice upgrade, but I really thought from all the research and reading that they would have made a bigger difference. Dont get me wrong the truck is faster acclerating, but once in 3rd gear it still falls flat on its face. Is there anything that can solve this stupid 3rd gear issue short of a custom trans with a different gear ratio? Maybe torque management is killing my acceleration? I dont know much about TM so if anyone can explain it would be greatly appericated.
