Cvi numbers?? - Hemi Truck Club
Old 12-11-2015, 03:02 PM   #1
Cvi numbers??
On the 03 rams. Does doing the TMR mod keep the cvi numbers from updating.
I don't think mine are updating. Gonna take it for a drive with scanner hooked up and see. If they don't any ideas what would cause that.
smith92rc is offline   Reply With Quote
Old 12-11-2015, 08:58 PM   #2
They don't really move that much at all unless somethings wearing out!
Old 12-11-2015, 09:07 PM   #3
so doing the torque management delete will not harm it. also, if i do a quick learn with my scanner, do i need to hokk that wire back up to the tcm...
Old 12-11-2015, 09:58 PM   #4
The TMR wire needs to be connected to do a quick learn (100% sure) and also to read the clutch values. (75% sure). It throws a communication error if the wire is disconnected at the dealer using their scanner.
Old 12-11-2015, 10:02 PM   #5
I did a quick learn 4 times in a row during one visit to the dealer just to see the results. Each quick learn produced different results and I believe this is a underlining reason for the issues with the 45RFE transmission. (Poor controls / software and too large mechanical tolerances. )
Old 12-12-2015, 02:37 AM   #6
If you do a quick learn I would deff hook it back up. I have done quick learns back to back with same numbers or one changing just a number or two. If they swing all over then there may be an issue internally somewhere
Old 12-12-2015, 05:41 AM   #7
Ok when I did the quick learn, wire was still unhooked. Gonna hook it back up and redo it. Should I remove the sonnax booster too. Then hook it back up afterwards.
Old 12-12-2015, 05:42 AM   #8
Nah that should be fine it's only a pressure thing no volume
Old 12-12-2015, 11:33 AM   #9
Are you using the Snap On tool or going to the dealer?
Sold: 2003 Dodge Ram 1500
Old 12-12-2015, 01:09 PM   #10
I have a snapon tool..
