Cant Find The Popping - Hemi Truck Club
Old 07-31-2011, 03:59 PM   #1
Blkram88's Avatar
Ive done everything, well alomst everything lol. Upper and lower ball joints and outter tie rods, all in which needed to be done and stop most of the popping noise, but its back again. Mostly when the wheel is turned and the suspension is moving. The rack along with inner tie rods and sway bar links were replaced about 50,000 miles ago. Anyone have any ideas?
Performance Mods: Custom CAI, Power wire, Heddmen LT's, Cat delete, Dynojet Wideband 2 A/F Gauge, Custom Bent 2.50" Full Exhaust Into A Dynomax Ultra Flo X Muffler Dumped Before The Rear Axle, NGK 4306 plugs, Taylor '409' 10.4mm race wires, Circle D 2800-3000 Stall Converter, Sonnax Line Booster, 1 Ton Tranny Cooler, Motive 4.56 Gears, Comp cams 268 cam, 6.1L pushrods, 6.1L exhaust valve springs, SCT custom tune.
Wish List: Comp Custom Cam, 85mm TB, Milled And Worked Heads, Bored 40 Over(If Motor Ever Lets Go,) StageIII Valve Body, E Fan(Waiting For Install)
Blkram88 is offline   Reply With Quote
Old 07-31-2011, 03:59 PM   #2
Blkram88's Avatar
Old 07-31-2011, 06:52 PM   #3
BTeves's Avatar
@ 50,000 miles I would begin to suspect the inner tie rod ends again. Although I wouldn't rule out anything else you replaced at that time frame.
Old 09-21-2011, 04:35 PM   #4
300HP 20's's Avatar
I am very happy with the durability of all those parts, at a 110k the only thing I have bad is a tie rod (my fault, hit a curb.. hard) and the control arm bushings. My lowers are almost completely gone.. just get under there and look for bare, rubbed metal.
mine pops under heavy breaking, accel, turning.
ME=Kenson
Truck= 2003 White Sport RC/SB 4x2
Hemi Under Glass Intake, Thrush Welded, 2.5" Dual Exhaust, DMH E-Cutout, 6.1 Cam, Pushrods, Springs, Taylor Shorties, Predator HEMIFEVER Tuned, Gauges, Stock 20's with 285/50s, 3.92 Posi, APS Converter, Couple Thousand Watt Stereo
Looking for a junk set of heads and/or valves
300HP 20's is offline   Reply With Quote
