behllhousings for 5,7l hemi - Hemi Truck Club
Old 09-20-2015, 07:29 AM   #1
which bellhousings fits the 5,7l hemi? does the V10 t56 trans bellhousing share the same bolt pattern?
any information would be helpful!
Davey is offline   Reply With Quote
Old 09-20-2015, 07:43 AM   #2
You will need an adapter I believe to make it fit a hemi engine.
Otnielarencibia did a full srt10 drivetrain swap if I remember correctly and needed the adapter for the trans to motor along with a starter for a 2500 hemi 4x4 I think been awhile.
Old 09-20-2015, 10:06 AM   #3
did he make the adapter on his own or where can i obtain it? any pictures of it?
Old 09-20-2015, 11:12 AM   #4
Truck of the year 2014
Belgiquebasterd's Avatar
SRT10 bellhousing does not fit, tested this personally.
You can either use a quicktime (expensive) or a challenger bellhousing (cheaper).
I recently did a T56 swap into a 3 gen ram, more info: http://www.hemitruckclub.com/forums/...ans-14249.html
Old 09-20-2015, 11:19 AM   #5
He bought it from somewhere
Old 09-20-2015, 11:21 AM   #6
He also used a quicktime.
Old 09-20-2015, 11:23 AM   #7
me who recently found cheap dodge v10 bellhousings... doh!
i have to modify the bellhousing to work with the trans im going to use so a quicktime bellhousing is no option. the dodge v10 bellhousing would have been neat couse then i could have built a plate to fit the trans and then just bolted it to the bellhousing.
noone happens to have any cheap bellhousing laying around?
Old 09-20-2015, 11:27 AM   #8
What are you attempting to do? T56 swap onto a hemi or something different?
Old 09-20-2015, 12:04 PM   #9
six speed bmw gearbox + button flywheel onto hemi. too poor for the t56 swap.
Old 09-20-2015, 12:30 PM   #10
Cool always like 'out of the box' projects :-). I've got a spare hemi block and a couple of srt10 bellhousings in my workshop, if you need any measurements or something let me know, glad to help.
