We'll see if they will let me and Mark test one out(only for FREE). If it works as they say it does, I would be willing to do more testing with their ATS trans also. Can guarantee you, I'll beat the dog poo out of it for sure! Can do testing with the 03, then the 05.
That means, EVERY Funday Sunday, Midnight Madness and any other drag racing I can get in at Orlando Speed World. Multiple down shifts into 3rd, 2nd gear boosting, ect, ect! Hell, might even get a trailer to tow Marks truck to the track. Then race the dog poo out of the my truck. Then tow Marks truck back home.... Want to do a dyno on the 03 at 14psi boost too. I'll make sure Mark beats the dog poo out of his truck also. :thumb:
Now it's up to you (ATS) Ryan & Dennis to set us up for testing your ATS products(FREE of charge of course). Me and Mark will supply all the info and testing data to ATS. Lets do some REAL testing! I will give you a call Ryan & Dennis to introduce myself also.
Marks Turbo Hemi(5.7) Regular Cab 05 Ram Truck:
Stock with the exception of a rear mount turbo running 8-9psi boost(at least 100rwhp added) with charged392(Keith) tuning. He has a front mount air to air intercooler. Plans on forging his Hemi engine for more boost.
Stu's Turbo Hemi(5.7) Quad Cab 03 Ram Truck:
Forged 348cid(5.7), 9:1 cr, RV camshaft, ported & polished gen 3 heads, s/s oem size intake & exhaust valves, PSI valve springs, forged Manley push rods, ARP head & main studs, 6.1 Hemi timing chain & oil pump, front mount T76 turbo, air to water intercooler, Snow stage 2 water/meth kit, 50lb(@49psif) injectors, custom twin fuel pressure regulators(raise or lower fuel pressure to the boost I want to run, 6 to 14psi boost), 400plh fuel pump, 84mm throttle body, KRC boost tune, 4" full length exhaust system with twin diesel mufflers, Sharadon stage III trans with 2800 stall Edge Pro Torque converter, Sonnax line pressure booster, 4.56 gears, Caltracs traction bars, SRT10 22" wheels. Built this truck to be a daily driver as well as some track fun in full street trim. Did a dyno check/test, and it did 488rwhp/534rwtq with only 8psi boost. It now can run 14psi boost. Ran the truck at Gainesville dragway with 10psi boost in full street trim. It did a 12.8@109mph when it finally did get traction off the line with the street tires. Haven't ran it at the track (1/4 mile) with 14psi boost yet. Can provide vids of the truck racing at the track in full street trim/daily driver.
Stu's 05 Turbo 392 stroker Hemi Ram street/dragstrip Truck:
The build starts in 2017.:dance:
Build spec's: Top Secret! :lol:
