Anything else I should do when I get my gears done? - Hemi Truck Club
Old 12-03-2014, 07:34 PM   #1
Ariel
RAM4's Avatar
Do you guys recommend I get anything else done when I have my gears done? I'm have 4.56 motive gears with a master rebuild kits.
Old 12-03-2014, 08:28 PM   #2
David
ATXHEMI's Avatar
Definitely need to get some sort of locker if you don't have an lsd now. Detroit tru trac is a well known lsd. Unless you like one wheel peel.
Old 12-04-2014, 07:27 PM   #3
Ariel
RAM4's Avatar
Do these trucks typically have LSD? I'm not sure if I do. I think I remember doing a burn out in the rain with both tires spinning. Is there any other way of telling??
Old 12-04-2014, 07:49 PM   #4
You should be able to look on the axel on the passenger side I believe an it tell you
Old 12-04-2014, 08:40 PM   #5
James
DakotaJ's Avatar
Just jack the back end up, and spin the tires. If they both go the same direction, your go. If not, then I'd start shopping for one. Good luck, and tell us what you think of them.
Old 12-04-2014, 09:32 PM   #6
Ariel
RAM4's Avatar
What do you guys run? I had lockers on a ratrod I had and it sucked at turning. I'm guessing LSD for street.
Old 12-04-2014, 11:05 PM   #7
Detroit true Trac here issue free clutch free.
Old 12-05-2014, 08:10 AM   #8
john
Exclamation
you are better off with the Detroit true trac go to randy's ring and pinion dot com in doing my research on lockers and limited slips the detroit is pretty much maintenance free ,,,according to my mechanic u mite hear an little cheap when turning real tie turns like in parking lots but the advantages out weigh the disadvantages if ur truck came stock with the 3.92 ring gear most likely it is limited slip if it is running the 3.55 gears it is most likely the standard unit u can also contact dodge and have them send u a print out/ build sheet of what was on your truck when it left the factory or the window sticker if u brought it new you can also go to your local dodge dealer and with ur vehicles vin then can tell u as long as it has not been change yet and fyi during my research i found out that eaton makes the Detroit lockers '''''''' I DONT KNOW THAT"""""""" CALL ME STUPID
Diff Wizard suggests True-Trac limited slip for Chrysler 9.25" rear with 31 spline axles - TT 913A368
Differentials and Traction Control
Old 12-05-2014, 08:21 AM   #9
john
ok now i have a question i know the ring and pinion need to be a match set pretty much. i have found two company that make them for the 9.25 rear ends, do i have to go with their locker's and posi units. or can i go with what i want to as in{ the yukon ring and pinion with the Detroit true tac unit}
Old 12-05-2014, 12:13 PM   #10
I have Yukon 456 gears with a factory posi(thank you Stu ) an my truck came factory w/ 3.55 an open diff
