6spd to 8spd Upgrade possible? - Hemi Truck Club
Old 08-05-2016, 07:08 AM   #1
Does anyone know if it's a fairly easy swap to change out the 6 spd auto to the 8 spd auto? Would you need a different ECU/PCM, or just a retune? Any info you can provide would be much appreciated.
Also, What is the designation of the 8spd in the 1500 series? I know the 6spd is the 65RFE.
NickPohlAandP is offline   Reply With Quote
Old 08-05-2016, 07:30 AM   #2
Red Trucker
HemiLonestar's Avatar
Not easy at all. As I understand it the trans programming is actually in the trans case somewhere in the new 8HP's (truck is 8HP70, diesels and Hellcats 8HP90).
2012 SRT Charger & 2003 Hemi Ram
Old 08-05-2016, 09:16 AM   #3
It's very easy. Your truck will have a different serial # and keys and you can choose another color too!
Sold: 2003 Dodge Ram 1500
Old 08-05-2016, 11:17 AM   #4
That is not a possibility sorry. You will be spending a ton of money if it's even possible to do at all to make it work. The 8speed is internally programmed just like a Beamer is. Don't get me wrong it would be cool but for the money I would save for something else.
Old 08-05-2016, 11:41 AM   #5
Thanks for the info. Internally programmed = not easily doable. I'll stay happy with my 65RFE.
Old 08-05-2016, 12:02 PM   #6
Step one go to dealer, step 2 pick your ram equipped w/8 speed, step 3 trade yours in
Old 08-05-2016, 12:04 PM   #7
I know nothing about this transmission, but being "Internally programmed" wouldn't that mean self contained? Does the trans have a separate module? Would need to look over the pin-out to see what inputs are needed. If you are serious then do the research to see what needs to be done before deciding it's a no go... my 2 cents..
Old 08-05-2016, 05:12 PM   #8
There's a ton more to it. The controller needs a lot of inputs from the pcm to even function or it will limp mode out. This is one setup that will need to be mated to a pcm setuo for it. If you want an 8 speed but the truck it's in.
Old 08-05-2016, 07:28 PM   #9
CavRam's Avatar
Kinda like a transgender. If it was born an 8 speed, everything works OK, but if you start changing over, things don't work like they supposed to.
2014 Ram 1500 Express
Old 08-05-2016, 07:30 PM   #10
Talking
