24Likes
08-17-2020, 10:10 PM
#1
Ariel
545RFE to 46RE KIT
What do you guys think of this kit? Is it worth the cost? I kinda think its too expensive but not sure? Ive been thinking of buying all the parts as funds allow until I have everything i need to get the swap done. I need to get this done to have better control of the pre boost/ trans shifting issue I've been experiencing for a while now. What do you guys think it’ll cost to get everything from trans to all the parts needed to make it strong?
https://www.coperacingtrans.com/?pro...4x4-gen-3-hemi
08-18-2020, 07:50 AM
#2
I have issues with John Cope, he owes me money and is not trust worthy from the dealings I've had with him. The flex plate is around $115, starter motor around $185. Floor shifter (??) you can make up your cooling lines. Cross member just needs the mounting holes elongated. Drive shaft fits. Keith is the forum goto guy for this conversion. Martin Saine IMO the goto guy for 700hp - 1000+ hp trans and ultra billet converters rated for 1000+hp transbrakes.
My recommendation is build your own kit....
Current 1/4 mile [email protected] (2018)
HTC 2020 TOTM
08-18-2020, 11:18 AM
#3
08-18-2020, 04:14 PM
#4
Just my opinion...
Go with an ATS built 545rfe and Copilot. ATS really has gotten the 545rfe trans problems worked out. Really happy with my ATS setup. It shifts nice and it's holding the power. And it works great with a 3000 stall tc.
Key note: ATS uses the Smart Tech hub as well.
But, if you instantiate on using the 46re. Keith is your man.
08-18-2020, 04:19 PM
#5
Ariel
Thanks i thought i remembered reading about Cope owing you money. I figured the kit might be overpriced. I do plan on piecing together my own kit then handing it off to Keith for the build. Moneys tight lately if not id buy all the parts at once. Gonna start looking for a 46re. If i find one does it need to be off a 4x4 truck since id like to keep my 4x4 working?
08-18-2020, 04:21 PM
#6
Ariel
Originally Posted by Ghost03hemi
Just my opinion...
Thanks Stu ive thought about the ATS but if I remember correctly I don't think i can swing the price on one.
08-19-2020, 12:05 PM
#7
Tyler
After owning an eight speed and now with the swap being possible for our gen 3 trucks I would say to give it some thought. It isn't cheap though but I have more than double into my 545 as I have currently into my eight speed.
Mods:
08-19-2020, 07:18 PM
#8
Would like to see a step by step procedure on that swap.
08-19-2020, 07:53 PM
#9
Ariel
I just found a note I saved on my phone saying I need a 46RH but i don't remember why. Maybe to keep the 4x4?
08-20-2020, 06:34 PM
#10
Mark G Senior Member
I am using the ATS 545 with a co-pilot it does work very well! but the 46rh would probably be a much cheaper alternative.
Please Donate today!
I STAND FOR THE FLAG!
[email protected]
Thread Tools |
Display Modes |
Linear Mode
» Premium Vendor Showcase |
» Technical Discussions |
