545rfe
2K views 10 replies 8 participants last post by  HemiFun05
My transmission shifts slow. A friend cut a green wire on the transmission but can't remember where. Does anyone know which wire and where. Thanks
#2 ·
It’s probably the torque management wire. It’s only an option to do on an 02 and 03 truck. On the TCM plug you want to find the yellow wire with a green tracer. I’m pretty sure it’s pin 10, but double check the wire color. Basically it will firm up the shift between 1st and 2nd gear going full throttle. I had this done for awhile before I changed to a newer computer system. It’s a nice little mod, but again, it’s only for 02 and 03 trucks.
I was reading through old Dodge forum posts double checking my info, it was was quite funny reading the comments of people flipping out about cutting this wire. Lots of insults thrown around haha
#6 ·
Yep, it can only be done if the truck has a seperate TCM. IMO, its a good mod.
#9 ·
At least he knew where to go to ask a question and actually get an answer.
