4wd clank - Hemi Truck Club
Old 11-17-2007, 08:24 AM   #1
Bama's Avatar
4wd clank
when 4wd disengages it clank's.. Is this normal????
Old 11-17-2007, 01:52 PM   #2
Freeze's Avatar
4wd clank
No, that's not even a little bit normal. Get it checked out at the dealership ASAP and don't settle for "we couldn't find anything wrong with it." Make them fix or replace it.
Old 11-18-2007, 08:14 AM   #3
Bama's Avatar
4wd clank
thanks Mr Freeze
Old 11-18-2007, 05:36 PM   #4
HEMI-PUP's Avatar
4wd clank
Like Freeze says, that sure doesn't sound right. The only time I think you might hear or feel anything is if you've got axle-wrap, binding in the 4WD system.
Before taking it out of 4WD, try backing up about 50 feet in a straight line, then shift out of 4X4 and see if it's any different.
Pup
Old 11-19-2007, 12:47 PM   #5
Bama's Avatar
4wd clank
Thank's guy's.. I have only put-er in 4wd twice since I have gotten-her.. I changed the front gear lube (amsoil) since the first time... She has been parked for the weekend, I tend to try again before I take-her in...The gear lube did'nt hurt... did it???
Old 11-23-2007, 11:50 AM   #6
Freeze's Avatar
4wd clank
quote:The gear lube did'nt hurt... did it???
Highly unlikely. Sounds like a t-fer case problem.
Old 11-28-2007, 07:57 AM   #7
Muddie Beast's Avatar
4wd clank
alright if it is a minor grinding sound when you engage or disengage the 4wd then that was kinda normal if you didnt engage it properly I know when i used mine the first time it wasnt fully in drive so when i tried to go it was grinding for a sec till it completely engaged. But for about a month or two after when i would put it in reverse it made a slight grind noise but it is gone now. i didnt ruin my t case or tranny or anything in the tranny it was a normal thing for me ive heard it before when i had the manual shift 4x4 in the chevy so i chalked it up to first time use and dodges tranny problem before the recall ugh lol.
Muddie Beast is offline   Reply With Quote
Old 11-30-2007, 01:32 PM   #8
Bama's Avatar
4wd clank
MB,..... exactly same thing here on the first time...It grinded a lil bit & I just chalked it up....This 2nd time It did'nt grind going in but clanked (loud coming out!)... I'm taken-er in soon for some other stuff & I reckon we'll go from there... Thanx
