4.56 ring gear too big (help) - Hemi Truck Club
Like Tree5Likes
Old 06-22-2019, 11:50 AM   #1
SnakeJr's Avatar
Hey yall. I have a 08 dodge ram 1500 5.7
I just bought a ring and pinion gear to change it to 4.56. However I'm trying to install the pin that goes between the spiders and the ring gear is sticking out too much. I have checked all part numbers and they all match up. Any help would be appreciated
SnakeJr is offline   Reply With Quote
Old 06-22-2019, 01:11 PM   #2
Assuming the 08 rear end is same as 03-06 axles you often need to grind a notch in the ring or pin.. i think the DDT carrier is the only carrier notching isn't necessary. Time to research...
Old 06-22-2019, 01:34 PM   #3
DDT with the Motive components fit perfectly and function flawlessly
Old 06-22-2019, 03:32 PM   #4
SnakeJr's Avatar
Thanks Red. I contacted my tuner and he said grind it. I have a mill at the shop so it came out nice
Redtruck-VA likes this.
Old 06-22-2019, 07:20 PM   #5
Well done..
Old 06-23-2019, 04:31 PM   #6
SnakeJr's Avatar
I did a few pulls today. The break in from the manufacturer was really light it seemed. Drive 10 miles let it cool down for 30 mins. 2-3 times. I did that yesterday.
Today I drove for 8 miles jumped out and put an ir temp gauge on it. 145F was the hottest spot. I figured it was time to do some pulls. Man what a difference. I am very pleased with the swap. I did notice from 60-70 mph deceleration that there was a slight whine. I'm going to drive it for a bit then do a oil change and see how it looks.
Overall very happy with the turn out
kcd1369 and Redtruck-VA like this.
Old 06-23-2019, 07:07 PM   #7
A procedure I've never seen in print and seldom mentioned is when installing the pinion gear while torquing the nut. Take a large drift or long 1/2" extension and hit the pinion head a couple times with a 1lb shop hammer. If this isn't done the pinion nut will need to be retorqued after breakin..
HemiFun05 and YeahItsAHemi like this.
Old 06-23-2019, 07:26 PM   #8
SnakeJr's Avatar
So you think all the gears settled and the backlash needs to be tightened? Would make sense for the whine
Old 06-23-2019, 08:28 PM   #9
If the pinion wasn't seated odds are the nut is nolonger torqued to spec after a heat cycle or two. Let us know what you find..
Old 06-23-2019, 08:38 PM   #10
It’s not uncommon to hear a whine on a 4.56 gear at some point in the range. Mine with the three sets I had did it all at diff times. One set whined a touch around 85 another whined right around 60 of the gas and last set I had whined around 40-50 letting off. Develop noise I would not worry about at all but accel noise deff check that. The pinion nut can loosen up if not seated double check and make sure it is still snug. I just use a lot of red loctite on mine no peening them over just Incase I need to remove. Deff give the pinion a few taps with a center punch when torque to make sure it’s all seated in
