After reading through some of the archives, I found mention of a mod to the 2003 TCM's only and decided to see what it was about. This mod onlt comes into play at WOT, and it definitely firms up the shifts. The shifts are still not where I would like them so I will still do a Transgo 45RFE-HD2 kit either this fall or next spring. Now onto pics...
1)Disconnect battery
2)Remove the TCM connector by loosening the 8mm bolt (black plastic cover over wire bundle on passenger side firewall/inner fender corner).
3)Remove the plastic shroud over the connector wire bundle. Has 4 clips holding it on.
4)Locate pin #10 with the yellow wire/ green stripe.
5)Remove the red clip on the TCM side secureing the group of wires having pin #10. Be gentle, I found a small thin knife blade works well. Pry up a little on each corner of the clip at a time.
6)Once the red clip is removed, you will need a straight pin and a flash light. Using the flashlight, look down inside the connector where the red clip was and you will see a small tab holding each wire in place. Use the straight pin to pry the tab away from the wire slightly and at the same time push pin 10 wire into the connector then pull out. The wire should pull out fairly easy doing this step correctly.
7) Once out, replace the red clip, tape the end of pin 10 wire with electrical tape and bundle it on top of the wire bundle going into the connector. Replace the plastic shroud over the wire bundle then replace the connector into the TCM and tighten the 8mm bolt being careful not to over tighten.
8) Reconnect the battery
Is this feature nulled when using the SC programmer?
What happens to functions of the truck?
I.E. shifting/braking/throttle response/OD
I thought this diabled ABS...
2003 4x4 w/SC intalled.
patches This message has been edited. Last edited by: patches906, document.write(''+ myTimeZone('Thu, 07 Feb 2008 20:12:07 GMT-0800', '07 February 2008 11:12 PM')+''); 07 February 2008 11:12 PM
