1993 Ford E150 tranny problem - Hemi Truck Club
Old 04-03-2005, 09:53 PM   #1
The van has a 4.9, auto. The transmission shifts into 2nd and 3rd gear right away. I've checked out the passing gear cable and the vacuum hose and both are ok. Could it be the modulator?
finnuts is offline   Reply With Quote
Old 04-04-2005, 06:43 AM   #2
Superjay? Any ideas?
Old 04-04-2005, 09:26 AM   #3
Sorry, no can help on that one.
Old 04-05-2005, 09:15 AM   #4
pm me some more info as to what kind of trans, what's recently been done, etc and I'll see if I can help.
Twist 2 Go is offline   Reply With Quote
Old 04-05-2005, 09:11 PM   #5
The trans is the old c-6 three speed. I bought the van with 149 k miles on it a few years ago and now it's got 189 k miles, and I dont know if the previous owner ever had any work done to it. I can shift it manually with no problems. I also changed the fluid, it was pretty dirty and i couldnt tell if there was any metal fragments in it.
Old 04-06-2005, 05:58 AM   #6
Sounds like a modulator valve. Also, make sure you used the correct fluid in it. It should take Dextron/Mercon fluid.
Old 04-06-2005, 08:31 PM   #7
Yea it's got dex-mec in it but from the looks of the drained fluid, I think its seen it's day. Can I replace the modulator without pulling the pan? Thanks for all the advise!!!
Old 04-06-2005, 09:59 PM   #8
yes, you can. remove the vacuum hose and the one bolt for the holddown bracket. pull the modulator valve out and there will be a short metal pin about 1-1/2" long on the end of it. Don't lose it and make sure you reinstall it. If the fluid is really dirty, you might want to change it again and drain the torque converter as well. there will be a drain plug onthe front of it that can be accessed through the small plate at the bottom of the bellhousing. Hope this helps.
Old 04-07-2005, 05:29 PM   #9
Thanks Twist 2 Go. I'll check it out over the week end and hope for the best. Have a good one!
