06 trans noise - Hemi Truck Club
Old 05-18-2015, 04:05 PM   #1
knightmoves's Avatar
06 trans noise
Ok you guys have heard a manual trans rattle when you use to high of a gear without enough RPM's? well my 545 makes that noise like it needs to down shift but doesn't. it just rattles like a bad throw out bearing or something. Any one got any ideas?
Better to be silent and thought a fool than to open your mouth and remove all doubt!!
knightmoves is offline   Reply With Quote
Old 05-18-2015, 04:28 PM   #2
U joints? if the noise is coming from the front of the trans, maybe flexplate is loose.
Old 05-19-2015, 05:42 AM   #3
I'll give the U joints a shake and see if any are bad. Does the 545 have an inspection plate so I can look at the flexplate? Funny I haven't really been under there to look!!!LOL
Old 05-19-2015, 05:50 PM   #4
Yes and No. There is a lower trans brace that can be removed and then you can see the flexplate. You
May have to also drop a small crossmember there as well to get the cover out of the way.
