04 hemi loosening power underload?? - Hemi Truck Club
Old 02-01-2015, 07:35 PM   #1
haulenhemi's Avatar
I have a 04 2500 hemi yesterday it would loose power
Underload like going up hill
like it's not running on all cyl. If you drive in 2nd gear it's fine
When idling it goes all over the place 300-1200rpm.
Any ideas? About ready for a old cummins.
2004 2500 4dr long box
BIG BLUE
only mod is superchip
but planning on many more.
haulenhemi is offline   Reply With Quote
Old 02-01-2015, 08:11 PM   #2
When was the spark plugs last changed? TB removed and cleaned? Air filter? What codes are you getting?
Old 02-01-2015, 08:15 PM   #3
odd. rpm jumping and lack of load power sound like a fuel issue or catt issue. any codes?
Old 02-01-2015, 09:00 PM   #4
haulenhemi's Avatar
Plugs were changed 10k ago just cleaned tb
Got new exhaust manifolds and gaskets last year
Just filled tank with of 91 octane in been running 87
Could be fuel related mmm.
I'll check codes tomorrow. Just scares me when you do Google
search could be a lot of things.
BIG BLUE
Old 02-01-2015, 09:13 PM   #5
The 04 fuel pressure is regulated to 58 psi. There is a Schrader valve on the passenger side forward fuel rail where you can check the pressure. When you turn the ign key on the pump runs for a few seconds and then shuts down waiting on a crank signal to provide a run sense to the PCM.
