stock H/U going, need advice on nav - Hemi Truck Club
Old 12-12-2008, 09:43 AM   #1
Jhrod's Avatar
In my 07, I have the base single cd with sirius and 4 speakers. Not so good as far as quality of sound. Now that My vw is gone the hemi is my DD and it's time to upgrade. I'll be installing an in dash screen (narrowed down to JVC or pioneer) with dvd, nav, ipod, and sirius ready. I found the dash kit but my question is on the install. Crotchfield says that there is no constant 12v's available and wants to sell me a contraption to for 70 bux to make one. There's gotta be an easier way. Any idea how to reuse the factory sirius antenna ?? Door speakers are next too so any reccommendations will be appreciated
Any tips, tricks, or advice on this upgrade will be appreciated. I'd like to order asap
Jhrod is offline   Reply With Quote
Old 12-12-2008, 02:38 PM   #2
UsmcMan96's Avatar
Not sure about the $70 addition, but if Crutchfield reccomneds it, you may need it. I believe you can re-use the factory Sirius antennae but am unsure. As far as replacement door speakers, look for a deal on Crutchfield, I was able to get the Infiniti 6x9's for the doors, 5.25s for the rear and some 3.5's for the dash ofr 70% off last year.
Old 12-12-2008, 04:25 PM   #3
sppb's Avatar
hard to believe there in no constant 12V but if it's true you just conect it straight to the battery with a fused wire.
not sure about the sirius i don't know of any adapter but you can get a compatible tuner and attena for cheep on Ebay.
Old 12-12-2008, 08:01 PM   #4
Jhrod's Avatar
CORRECTION
There is no switched ACC power in this harness. The extra wiring kit is a CAN BUS which creates a swithced source. Can't i just add a wire from the fuse panel thats switched and can handle the load of the h/u?
Old 12-12-2008, 09:11 PM   #5
rdsetgo's Avatar
That is not true about the ACC power how could the radio keep time and when you push the time button with the truck off it will tell you the time.... As far as a wiring hook up you should be able to get one from just about anywhere. I am not sure about the Sirius end...
Old 12-12-2008, 10:19 PM   #6
Old 12-13-2008, 08:16 AM   #7
Jhrod's Avatar
Its keeps time because it has a constant source but no switched source so the a/m radio will not know when to shut off. Don't ask me how the factory one does but thats what i get out it anyway
Old 12-13-2008, 03:41 PM   #8
rdsetgo's Avatar
It does have a swithced source, but what I think they are talking about is the radio turns off after it times out or when you open the door after you shut off the turck. This is for 2007 and up!
Old 12-13-2008, 04:08 PM   #9
sppb's Avatar
quote:There is no switched ACC power in this harness. The extra wiring kit is a CAN BUS which creates a swithced source. Can't i just add a wire from the fuse panel thats switched and can handle the load of the h/u?
Ok, that i understand, the CAN BUS sends an coded signal to the Head unit to turn on or off, and uses the permanent 12V.
You can connect it to the fuse panel and a 5 amp fuse it's eneugh all it does is switch a small internal relay
Old 12-13-2008, 04:26 PM   #10
sppb's Avatar
actually what i meant was the Ignition sends a CAN BUS signal to the head unit, the factory head unit has a built in CAN BUS decoder.
A couple of other factory stuff might not work without it like satellite radio, shut off delay,navigation and video steering wheel remote, as they all use CAN bus to communicate with the head unit.
