Questions...advice - Hemi Truck Club
Old 07-20-2008, 09:26 PM   #1
rentalguy1
Questions...advice
I'm installing a 300W Jensen 2-channel amp, and a 10" Kicker Comp in a '08 1500 Mega Cab. I've done this a billion times in other vehicles, but never one that was this loaded and had a sticker price of $45K...lol. The truck has the Infinity &-speaker system with the Sirius satellite junk (that I never seem to listen to).My questions are:
1. How do I remove the head unit?
2. Does the head unit have pre-amp outlets?
2a. If so, can I use a one into two splitter to power the my amp and the factory amp?
2b. If not, which wires to I need to tap to wire in the amp?
3. Is there a post with the wiring diagram for this system somewhere?
Thanks in advance!
Old 07-20-2008, 09:38 PM   #2
rentalguy1
Questions...advice
almost forgot. How do you remove the head unit in these trucks? They seem to make it harder every year.
Old 07-21-2008, 08:16 AM   #3
Dan O's Avatar
Questions...advice
Here's where the two screws are on an 07 I believe it's the same on an 08. If you don't have buckets.
I don't think there are 'RCA' Type preouts. You will have to tap into the speaker wires at the head unit. Not sure of the colors.
Dan O is offline   Reply With Quote
Old 07-21-2008, 09:47 AM   #4
rentalguy1
Questions...advice
so the whole center piece just pops out, like on most other vehicles. I'm not sure what the screws you are pointing at are for. It looks like the 4 screws surrounding the head unit would let you remove it.
Old 07-21-2008, 10:55 AM   #5
Dan O's Avatar
Questions...advice
You get to the screws by pulling the cup holder down and the screws are up in there. After you remove them, then the piece pulls out. Being careful not to damage the surrounding piece.
Old 07-21-2008, 01:00 PM   #6
rentalguy1
Questions...advice
now I get it...thx
Old 07-21-2008, 01:45 PM   #7
Dan O's Avatar
Questions...advice
No problem, let me know if you need anything else. Good luck!
Old 07-24-2008, 11:08 AM   #8
rentalguy1
Questions...advice
what color are the wires for the front speakers? Or are they easy to trace?
Old 07-24-2008, 11:29 AM   #9
Dan O's Avatar
Questions...advice
This is 07 not sure if 08 is the same.
+12V: Grey / Red
Radio Ground: Black and Black/Light Green
Radio Ignition (CAN data bus) ** See Note
LF Speaker +: Dark Green/Yellow
LF Speaker -: Dark Green/Light Blue
RF Speaker +: Gray/yellow
RF Speaker -: Gray/Light Blue
LR Speaker +: Gray/Light Green
LR Speaker -: Gray/Dark Green
RR Speaker +: Dark Green/Light Green
RR Speaker -: Dark Green/Gray
Old 07-24-2008, 12:21 PM   #10
rentalguy1
Questions...advice
Thanks!
Is that for the Infinity 7 speaker system?
