Polk db 650 - Hemi Truck Club
Old 09-10-2008, 09:42 AM   #1
zwa21's Avatar
Polk db 650
I have a set of Polk db650. Will they mount directly in or do they need brackets fabbed up?
Old 09-10-2008, 11:05 AM   #2
brand_x_racing's Avatar
Polk db 650
some speakers come with a plate, but those dont, great sounding speaker for a coax for sure, Personally get a piece of 1/4 or 1/2" mdf, take that factory spacer ring on the 6x9 off, trace the outside, pre drill the holes for the screw mounts, then cut out the 6.5 hole with the template they supply with the speaker, you can adust some to make it line up with the door opening, if your realllllly good you can space the speaker out even more and get it closer to the grill and help on some minor image issues. Wish I had pics of my install, OHHHH and i quick tip, when you put the adapter on the door, screw it on, dynamat around that about 5" gives some stiffer midbass from my experience! Hope this helps Bro!
Old 09-10-2008, 06:41 PM   #3
zwa21's Avatar
Polk db 650
I'll have to get someone to do it then. I have never done anything like that before.
Old 09-11-2008, 06:57 AM   #4
Polk db 650
its real easy with a jigsaw, no one will see it if ya mess up, home depo sells a 1/4 sheet of 1/4" mdf, I know you got some skills! LOL. If you have any questions always more than welcome to help!
Old 09-11-2008, 08:00 AM   #5
zwa21's Avatar
Polk db 650
I can get a saw. Might as well try it out. What's mdf?
Old 09-11-2008, 08:05 AM   #6
Polk db 650
MDF is multi density fiberboard, better than plywood and all that particle board stuff, very compressed and alot more substance to it, holds up for years upon years! its what they make speaker boxes out of alot of the time! Give it a try bro, I got some faith in ya!
Old 09-11-2008, 04:05 PM   #7
sppb's Avatar
Polk db 650
quote:Personally get a piece of 1/4 or 1/2" mdf, take that factory spacer ring on the 6x9 off, trace the outside, pre drill the holes for the screw mounts, then cut out the 6.5 hole with the template they supply with the speaker
Yep that's what i did on mine, 1/2" MDF
Old 09-11-2008, 07:05 PM   #8
zwa21's Avatar
Polk db 650
Do I use the existing wires?
Old 09-11-2008, 07:25 PM   #9
sppb's Avatar
Polk db 650
quoteo I use the existing wires?
you probably should, i used new OFC wiring but let me tell you it's a pain in the to pass them to the door
Old 09-12-2008, 10:10 AM   #10
zwa21's Avatar
Polk db 650
I'm currently searching for some mdf. Lowes around here doesn't carry it. But I'll keep looking.
Also, the speakers are from my other truck which now gets alot of dirty driving. The speakers are coating in fine dust. What is the best/safest way to clean them?
Maybe just crank them up???
