Newer better battery - Hemi Truck Club
Old 02-24-2013, 06:53 PM   #1
reen4967's Avatar
Guys im trying to stop my headlights from dimming so i want to upgrade my battery to a kinetik. i have a 1000 watt system but im still not sure how big of a battery i need because i dont know how many watts the truck uses to run. dont want to go with a cap because i dont want to see it or add anything else inside the truck. thanks
04 dodge ram rc/sb hemi
03 dodge ram qc/dually cummins
reen4967 is offline   Reply With Quote
Old 02-25-2013, 04:45 AM   #2
Sounds like you might want to upgrade your alternater.
Old 02-25-2013, 07:58 AM   #3
"Compaņero"'s Avatar
I went to crank up my Ram a few days ago after it had sat for 2 days. The 11 month old battery was door nail dead. So I got an exchange and installed it. I couldn't get it to fire for the longest time. Finally got a cough and figured it wasn't getting fuel. So going against the rules of EFC I pumped the gas and it finally sprang to life...just a little fyi for y'all.
~ Do not conquer the world with force, for force only causes resistance. Thorns spring up when an army passes. Years of misery follow a great victory. Do only what needs to be done without using violence. Lao Tzu ~
"Compaņero" is offline   Reply With Quote
Old 02-25-2013, 03:50 PM   #4
Saw a Nascar driver pumping the pedal trying to get his car re-started. The trick with most all Fuel injections is that holding the peddle to the floor clears flooding condition. If someone has other information pls post up.
Old 02-25-2013, 04:56 PM   #5
David
ATXHEMI's Avatar
Sounds to me like you need to add a capacitor to your system. Changing the battery may not solve your problem. Where in round rock are you. I live off 3406 and sunrise?
Old 02-25-2013, 09:33 PM   #6
Your going to need a cap for the stereo I run a yellow top optima and my truck would dim out during a good note.
As for the pumping the gas wot does put the truck into a clear flood mode turning off the Injectors only issue with this if there is enough fuel at the right point the cylinders will fire and rev up quick sometimes when I start my truck warm I have to go part throttle to increase the inj pulse with a little to get her fired but I partially blame that issue on the fact that its stroked and the cam I run
Old 02-26-2013, 08:32 PM   #7
reen4967's Avatar
adding a cap would just add more stuff to my behind the seat area.lol but if i must.
and ATXHEMI i live off of grimes and old settlers.
Old 02-27-2013, 11:21 AM   #8
David
ATXHEMI's Avatar
Damn we've prolly passed each other and never new it. Lol
Old 02-28-2013, 05:29 AM   #9
James
DakotaJ's Avatar
I would start off by doing the Big Three!
Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. Some people replace the factory wiring; others add additional cables to the factory wiring.
Having a 300amp alternator isn't going to help if all you have is an 8 ga. wire feeding the battery. If all you are wanting are your lights not to dime, possibly look into a set of good, (not cheap) set of HID's. They're a whole lot brighter then the typical head light bulb, and they won't dime. Mine are way brighter then the Silver Star Ultras I had. Stick with a 4000 to 6000 series for your whitest.
Old 03-02-2013, 06:17 PM   #10
reen4967's Avatar
yeah im for sure changing the big 3 first then ill see where i go from there. probably a cap now.
