engine noise?????????? - Hemi Truck Club
Old 09-02-2008, 06:06 PM   #1
well i installed my sub and amp and now i have engine noise. where shoul i start to try to get rid of it? i bought one those noise suppresor things and it didnt work at all. any help is greatly appreciated thanks.
finallygot1 is offline   Reply With Quote
Old 09-02-2008, 06:38 PM   #2
tigman250's Avatar
don't run the power and speaker wires together, if you do have to cross them do it at a 90 deg angle. get your amp power directly from the battery not the fuse pannel. lastly when i was younger i always bought cheaper equipment and had nothing but problems with noise feedback, when i did my amp sub install in my Ram i used Kicker components right down to the wiring harness and have ZERO engine noise issues. don't know if quality equipment has anything to do with eliminating noise issues but i'm sure it didn't hurt LOL.
Old 09-02-2008, 08:37 PM   #3
gottahemi's Avatar
Make sure you have a good Ground Connection. Also make sure that your Ground wire is no longer than about 18 inches.
gottahemi is offline   Reply With Quote
Old 09-03-2008, 01:50 AM   #4
my rca cables arent ran next to the power wire they are actually on opposite sides of the truck. ive done alot of installs and this is the first time i have ever had this problem and i have always used the wiring kits from wal-mart maybe i just have a bad set of rca cables.i have an extra set so i will try those and ill check the amp ground tomorrow.
Old 09-04-2008, 05:46 PM   #5
sppb's Avatar
it might just be your amp RCA input, sometimes the ground connection of the RCA brakes inside the amp or the RCA connectors ground is touching the metal.
It's definitely a ground problem
Old 09-05-2008, 08:48 AM   #6
brand_x_racing's Avatar
some cheaper amps will burn out the diode inside the radio put a ground wire from your radio to the place you grounded your amplifier, and if that still dosent work, take a ground from there also and ground out the outside part of the rca cable, where it attaches inputs to outputs, should get you quieter, but deff have a ground issue!
Old 09-05-2008, 09:37 AM   #7
whitelight's Avatar
quote:Originally posted by finallygot1:
...and i have always used the wiring kits from wal-mart...
Asside from all of the good advice already given, make sure the RCA isn't near any sources of interference like power motors (ac blower) etc.
whitelight is offline   Reply With Quote
Old 09-05-2008, 03:37 PM   #8
That is deff another point to ponder, I have my rca down pass. side and power down the drivers!
