Double din - Hemi Truck Club
Old 05-21-2008, 10:09 PM   #1
Double din
Is there a double din dash cover for 03's?
gary_lytle is offline   Reply With Quote
Old 05-22-2008, 05:20 PM   #2
sppb's Avatar
Double din
i remember seeing them on Ebay but they came from Germany and are extremely expensive, it's not that hard to customize yours, i did mine
http://cgi.ebay.com/ebaymotors/ws/eB...251033191&rd=1
Old 05-22-2008, 06:21 PM   #3
Silver Surfer
Double din
Old 06-07-2008, 07:54 PM   #4
Double din
how did u customize yours?!
Black Thunder is offline   Reply With Quote
Old 06-08-2008, 05:50 PM   #5
sppb's Avatar
Double din
Start by cutting the double din size on the stock trim, then cut some plastic ( acrylic or Plexiglas) to fill in the extra wide of the factory size, use crazy glue to secure it in place and then use some epoxy on the back to reinforce the patch, smooth everything up with Bondo body filler sand everything smooth and paint as you want.
That's how i did mine
Old 06-09-2008, 11:21 AM   #6
UsmcMan96's Avatar
Double din
That looks really nice. Would you be interested in making another one early next year?
Old 06-09-2008, 07:43 PM   #7
Double din
so what did u cut it with?
Old 06-10-2008, 04:14 PM   #8
sppb's Avatar
Double din
I used a DREMEL rotary tool I have the one with dozens of different attachments, great tool, Father's day is coming, just wish for one
Old 06-18-2008, 01:39 PM   #9
Double din
hey man i got it done, take a look at it. i just have a quick question, did u need a sleeve when u put the in-dash in?
Old 06-18-2008, 07:03 PM   #10
sppb's Avatar
Double din
see it wasn't that hard, good job
no i didn't use the sleeve i used 2 L brackets on the radio mounting points using the screws that come with it, i had to adjust the holes for a perfect fit but it wasn't that bad ( make sure the brackets are at least 1 inch wide to allow adjustment) , also had to cut some of the plastic inside the dash and the back of the radio is now standing on it so no need for tight fixation in the front
