Amp bypass and speaker rewire. - Hemi Truck Club
Old 04-19-2019, 06:56 PM   #1
StreetWiseMI's Avatar
My Ram came with an infinity sound system. Outdated as it is, i have put in a new touchscreen hud. Amp is out, speakers are set to be wired through. Anyone have any suggestions on how to get the new speaker wire through the rubber door boot with minimal frustration? I literally just have to reconnect the new wire to the unit and im done but cant see an easy route to run the wire. 🤔
StreetWiseMI is offline   Reply With Quote
Old 04-19-2019, 07:18 PM   #2
There really is not an easy way to do it as it’s an actual plug type setup. If there is extra room in the plastic plug you can drill thru it seen it done that way but makes it so you cannot take the door off without cutting the wires. You can also drill a small hole just below the plug and same woth the door
Old 04-20-2019, 07:05 AM   #3
Well i finagled and explored. Got the boots to pop off the body and ran wires from speaker harness all the way through to dash unit with a few pieces of hangar. So far so good for the front. Now onto the rear. May update. Will help if anyone is looking for tips in this area. Beats paying $800 for some shmuck to hack ur system up. 👍
Old 04-20-2019, 10:20 AM   #4
On my truck I actually just tapped the factory wires but I’m not running any crazy amount of power either. Good you found a way thru though
Old 04-20-2019, 10:43 AM   #5
Gold-Member
kcd1369's Avatar
I cut a slit in the boots when I ran my new wires in my 03 wire tied the cables to the rubber sleeve. Whenever I get around to putting my interior back in my 05 I will be running new 16AWG speaker wire in this one too. But it should be much easier with the complete interior out of it to do it correctly like you did. Even the seat belts are out so nothing is in the way.
