2 questions? _ need help! - Hemi Truck Club
Old 07-19-2007, 07:25 AM   #1
CRAZYHEMI's Avatar
What size is the front dash speakers? 5.25??
Also, installing an amp and want to know what all the settings are. What is the gain ect..., ect...
I know you stereo guys can give me a quick lesson.
I have 2 door Kenwood excellon 475 wt/100 rms and 2 rear Polk 150 wt rms in boxes in the rear as well as 2 infinity reference in back panel ( geting rid of them )
I'm not looking for a super loud thumping bass sound. I want clean clear sound mostly. So what kind of settings do I do on the amp??
Thanks
CRAZYHEMI is offline   Reply With Quote
Old 07-19-2007, 11:00 AM   #2
J Wett's Avatar
1st - Front dash speakers are 3 1/2.
2nd - Amp settings are for your own ears. Different speakers and different amps will produce different sounds so what I've done is turn the volume to about 3/4 then set amp from that point. Not all the way up but below distortion levels. Hope this helps.
J Wett
J Wett is offline   Reply With Quote
Old 07-19-2007, 12:32 PM   #3
CRAZYHEMI's Avatar
Yes that helps.
Just want to know what these do.
Gain:
High/low pass :
Can't remember other setting:
Old 07-19-2007, 06:22 PM   #4
J Wett's Avatar
Gain: basically a power level
high/low pass: high pass cuts off/down bass frequencies. low pass cuts off/down mids and highs
Old 07-19-2007, 06:31 PM   #5
High pass: blocks the low frequincies from going to your door/dash speakers. Keeps them from getting too much bass, used when running a sub.
Low pass: blocks the high frequincies from the sub.
You shouldn't have to worry about these unless you are running a sub.
I usually dont mess with the gain myself.
Heminthesouth is offline   Reply With Quote
Old 07-19-2007, 06:48 PM   #6
sppb's Avatar
they are 3 1/2 but you can fit 4" i have Rockford Fanatics 4" and they fit perfect, just had to make new holles
