08 ram factory stereo wiring pinout ??? - Hemi Truck Club
Old 12-03-2008, 08:24 PM   #1
is the 08 the same as 07 for the factory wiring color codes and wiring for the {RAQ w/infinity} stereo with blutooth and NO navigation???? this is all i can find anywhere. Does anyone truthfully and posatively know??? Please help!!
Infinity Sound System
FUNCTION PIN WIRE COLOR
Accessory 12 Volt SEE NOTE*
Constant 12 Volt 1,12 GY/RD
Chassis Ground 11
22 BK/L.GN
BK
Power Antenna
Remote
Illumination
Dimmer
FUSE VALUE FUSE LABEL FUSEBOX LOCATION
20 AMP #11 DRIVER'S SIDE UNDER HOOD
*The factory receiver does not use a traditional 12V Accessory power lead, rather it turns on and off through the data lines in pins #5 & #6. When installing an aftermarket stereo, a wire must be run to a 12V Accessory power source.
This Infinity Sound system has seven speakers. They consist of a 3-1/2" speaker in each dash corner, one 2-1/2" speaker in the center of the dash, a 6"x9" speaker in each front door (with a tweeter mounted in tandem), and 5-1/4" speaker in each rear location (with a tweeter mounted in tandem).
The factory amplifier is located behind the glovebox and must be bypassed if an aftermarket stereo is installed (it is controlled through the PCI Data Bus). Total power in this system is rated at 240W.
Left + to Amp 18 D.GN/D.BU
Left - to Amp 19 D.GN/OG
Right + to Amp 21 GY/D.BU
Right - to Amp 20 GY/OG
UConnect Hands-Free Cellular System 4
16
17 GY/TN
TN/GY
D.GN
PCI Data Bus 5
6 WT/OG*
WT*
DO NOT USE THESE WIRES!
Infinity Amplifier Wiring
L/F Door Spkr + 1 D.GN/YW
R/F Door Spkr + 2 GY/YW
Left Rear Spkr + 3 GY/L.GN*
Right Rear Spkr + 4 D.GN/L.GN*
L/F Door Spkr - 7 D.GN/L.BU
R/F Door Spkr - 8 GY/L.BU
Left Rear Spkr - 9 GY/D.GN*
Right Rear Spkr - 12 D.GN/GY*
The factory amplifier is located above and behind the glove box and is protected by a 25 AMP fuse labeled #36 that is located in the fuse box under the hood.
*Wiring at both rear speakers is GY/L.GN for ( + ) and GY/D.GN for ( - ). FUNCTION PIN WIRE COLOR
Left Dash Spkr + 15 GY/OG
Right Dash Spkr + 16 GY/D.GN
Center Dash Spkr + 17 GY/BN
Constant 12 Volt 18 YW/RD
PCI Data Bus 20 WT/OG
Left + Input 21 D.GN/D.BU
Right + Input 22 GY/D.BU
Chassis Ground 23 BK
Left Dash Spkr - 24 GY/YW
Right Dash Spkr - 25 GY/L.GN
Center Dash Spkr - 26 GY/OG
Constant 12 Volt 27 YW/RD
PCI Data Bus 31 WT
Left - Input 32 D.GN/OG
Right - Input 33 GY/OG
Chassis Ground 34 BK
Plan on putting a sub and amp in and need to know what to hook my line out converter to
08HEMILARAMIEBW is offline   Reply With Quote
Old 12-22-2008, 10:44 PM   #2
ok i got my amp sub and line converter in as well as an ipod interface that plugs in to the back of the factory stereo. the wiring colors in this post above were correct i found the speaker wires behind a panel right on the side under the dash on each drivers and pass side of the truck. the stereo wires are twisted togather, easy to spot. hooked the line converter to the speaker wires that come from the output of the factory amp to the factory front door 6*9s. the whole system works great.
Old 12-23-2008, 08:15 AM   #3
Lucky Devil's Avatar
Lucky Devil is offline   Reply With Quote
Old 12-23-2008, 10:27 PM   #4
Old 12-23-2008, 11:19 PM   #5
rdsetgo's Avatar
Great info
