Chris's 2003 6.4 Hemi Stroker Build - Hemi Truck Club
Old 09-01-2017, 07:13 PM   #1
Chris
YeahItsAHemi's Avatar
Well I had a thread about doing a cam swap, now that is over, time to re-start all over again and do it right! I do it nice, cause I do it twice!
I had really wanted to do a stroker kit the first time around, but time and financial constraints weren't allowing me to. But after I found out the fresh rebuild was burning major amounts of oil in cylinder 1, I decided to just go for it. To start the process, I chose to get a used 5.7 block and build the stroker first. When its all completed with the necessary machining and installation, I'll pull my old engine out and swap over the heads and accessories. I've already added a Comp 260, new valve train, torque converter, oil pump and timing set the first time around, so I have a good base to start with. So after a bit of searching, I found a blown engine at a local junkyard for $400. They didn't have any info on why it was blown or the mileage, but I figured I would be only using the bare block and it would be over-bored to begin with so it couldn't be too bad. Any other usable parts would be experimented with or sold to help recoup the cost. After pulling the heads I found the reason it was blown, cylinder 6 had no piston head left, it was completely blown out with just the rod and wrist pin left. So I will have to have one piston re-sleeved, I don't think that is a big deal in the end. Other then that, all the other cylinders are at standard bore size and should clean up well. At this point I have the engine stripped to the bare block, tomorrow I'll start with the wire brush to remove all the old paint and rust. Then it will be sent to my local performance shop to bore it out and get it re-sleeved.
I plan on using the SCAT Modern Muscle Stroker Kit from Summit Racing. It's in my price range and comes balanced. So feel free to pitch in any suggestions or tips!
Well the frame is an 03, but that's about it
392 Manley Stroker Kit, Inertia Custom Cam
05 PCM-06 Front End Swap-Custom Morimoto Projector Headlights
4th Gen Floor Console-Ridin the 545 Till It Dies
Tuned by Charged392
Tons of Pics https://www.flickr.com/photos/159420730@N03/albums
Old 09-01-2017, 07:17 PM   #2
Chris
So just a few basic questions as I'm starting, will I need to upgrade the fueling system at all? Bigger injectors? Fuel pump? Any other things need upgraded a bit to keep up with the extra displacement? I'm going to see how long my stock trans will hold up, then deal with an upgrade or swap...
Tuned by Charged392
Old 09-01-2017, 09:16 PM   #3
While in the machine shop I would have them replace the cam bearings.
2003 RCSB, 2wd, Street Truck
6.4L/SuperCharged/46rh trans/Armed-HTH
11.66@117.61mph 60'@1.72
Old 09-01-2017, 09:30 PM   #4
Chris
I noticed in the service manual it claimed these were not serviceable by the "average home mechanic". Any idea what makes these bearings so special?
Tuned by Charged392
Old 09-01-2017, 09:58 PM   #5
You will need the mandrels to drive each bearing into place with the rear bearing clocked specifically to the oil port. Most of these bearings I believe have a groove on the back shell and the exit hole is set to 5 o'clock. Double check this information to make sure it is correct for your application.
The 03 uses a 48psi fuel regulator. Not sure if you scaled your current injectors to compensate for this or not. 05 pcm used 58psi. I am not a fan of dead headed fuel delivery systems. I would remove the oem fuel regulator and use a external adjustable regulator with a a return line. Using the return line insures the fuel being provided to the injectors is relatively cool as it is fresh from being circulating. -6AN hose will support 750 hp and both -6 AN feed and return lines is suffient. Used 6.2 take off injectors are available from Modern Muscle which should be good for your build. I think they are something like 55 pound injectors. If they are too big, they can be scaled in your tune.
Old 09-01-2017, 10:39 PM   #6
The pump should hold but if I were you I would drop a walbro 255 into the factory basket and be done with it run it like stock and don't worry about it. Get stage 1 srt injectors or 6.2/6.4 stock hemi injectors will give you room to grow. The return style setup is suggested not required for what you wanna do IMO. Also my engine has a sleeve in cylinder 2 and I am boosted high compression lol and doing fine. Main thing is you will tune to the sleeved hole as that one willrun hotter than any others due to metal differences.
"CMR TUNER" 11.63@115.87 1/4 with a 7.32 1/8 custom long/short bars by "Me" Turbocharged 392 on 12psi S475/96/1.32 . Running thru an A518!
Old 09-01-2017, 11:12 PM   #7
Chris
Thanks guys, now to contact my machine shop and see if they can do sleeves
Tuned by Charged392
Old 09-02-2017, 02:58 AM   #8
Ghost03hemi's Avatar
I know you don't want to here this....
Don't waste your time and money on that engine block. There's more damage there than you know. Build your stroker out of an engine that runs with no problems.
03 QCSB, 5752lbs, 03 PCM
Turbo, 5.7 Hemi, KRC Tune
12.79@103mph, "Full Street Trim"
https://www.youtube.com/watch?v=RQ72xXx5dck
05 RCSB, stock
Old 09-02-2017, 06:00 AM   #9
ric3xrt's Avatar
Is the cylinder cracked? Have it magnafluxed, and sonic check . Check the webbing under the bore in main bearing area ,should be fine , small end of the rod is still there but strange things happen when a Piston disappears.
Cam bearings in these are not an easy install, it boils down to right tools for the job and a little bit of experience.
As for the Fuel system and tune......I'm just going to sit back and eat my pop corn and listen to the advice that's given.
ric3xrt is online now   Reply With Quote
Old 09-02-2017, 08:28 AM   #10
Chris
When I took off the timing cover I discovered the timing tensioner was broken. I'm assuming that's what caused the piston to blow. That seems to be a common problem on these engines. When I pulled apart my other engine the tensioner broke in my hand with very little force, so I think it was only a matter of time before this happened to me.
I'll see what my machinist has to say about it first. Other then the cylinder chamber and the sleeve, nothing else is damaged. No webbing or anything down in the block is damaged, all the bearings still looked in good shape. The block hasn't been bored or rebuilt, and all the other cylinders looked in better shape then my old block. No score marks to speak of. So we shall see.
One of the other minor upgrades I want to do while I'm at it is clean up the intake manifold and make it look decently nice. I think I'll add in the Taylor shortie wires at least, I'm also interested in the 6.1 coil swap. I saw someone who grinded off all the extra plastic on the intake manifold to clean it up and paint it, turned out nice. Anyone know if all the plastic fins and ridges are from molding, for extra ridgidness, or for cooling purposes? I'll have to find the picture of his intake. I have the extra manifold that came off the engine, so I figured I could play around with it on the bench and see what I can do.
Tuned by Charged392
