Redtruck's never ending tale.... - Hemi Truck Club
Join Hemi Truck Club Today
Old 05-27-2015, 01:31 PM   #1
With the 46RH conversion successfully completed. Redtruck is in need of a mod or two. Next up is to finally get her tune dialed in. Keith has been doing the heavy lifting and I'm trying to give him a platform that is easier to work on than the Manual flashed automatic based PCM. According to B&G the current pcm flashed to manual trans can have issues due to software and hardware not being terminated properly. Bought a 03 manual PCM from ebay and found it to be junk. Apparently locked up from security lacking compatibility with my truck. Can't tell for sure since I took it to B&G to have it checked and it was DOA. Still going to use it for a core for a new PCM I've ordered. Told the guy it was dead and had been opened but he said "no problem". Manual trans PCM are a fairly rare bird just to note the obvious. The good news is the same pcm is used in Ram 1500, 2500 and 3500. And the vin doesn't necessarily need to match the vehicle. I ran a salvage yard pcm for a couple years before I reflashed it with a vin. Anyway next mod, take the new pcm to Dave@B&G for him to adjust idle, rev and speed limiters. Install a pair of BV heads. Then tune the old girl. I bought one of those push rod holders, so hopefully I won't have the same difficulties I had last time. So that's the run down on Red it's all good...
Redtruck-VA, 2003 Regular Cab, Short Bed, 2wd SXT SuperCharged Hemi/46RH trans.
12.37 @ 111mph
CMR Tuned by Charged392
Support vehicle- 2007 QC 6spd 4x4 diesel
Old 05-27-2015, 02:08 PM   #2
Truck of the year 2014
Belgiquebasterd's Avatar
Good luck, I'm starting to hate the stock pcm with a passion. Freshly flashed my truck idles like normal, the longer I drive it (the more the pcm 'learns') the worse the rpm fluctuations at idle get:-(, stupid thing.
Getting closer and closer to putting in an aftermarket engine management system!
Old 05-27-2015, 04:32 PM   #3
Christof, I fully understand. I still have my Megasquirt setup I'm sure we could work out a deal on. But keep in mind with our trucks making the engine run using a stand alone is the easy part. It's the rest of the trucks equipment/accessories which is the problem.
12.37 @ 111mph
Old 05-27-2015, 07:25 PM   #4
Old 05-27-2015, 07:37 PM   #5
Higher the mountain, the more satisfaction when climbed. If I didn't have state inspections I would have it stripped running a stand alone. But being what it is, I've been close a couple of times. The new PCM should arrive in a few days. This one will be fully tuned. Yesterday I stood next to a Chally with twin turbo's and a serious lobe. I was told it made over a 1000hp and was drivable as a grocery getter.. pure music..
12.37 @ 111mph
Old 05-27-2015, 08:04 PM   #6
This saddens me
"CMR TUNER" 11.63@115.87 1/4 with a 7.32 1/8 custom long/short bars by "Me" Supercharged 392 on 15psi YSI-V7. Running thru an A518!
Old 05-27-2015, 08:15 PM   #7
Sorry brother they also supercharge a lot of street cars.. The superchargers I believe are more reliable on the street running 5-8 psi.
12.37 @ 111mph
Old 05-27-2015, 08:21 PM   #8
Oh no I fully understand having them tune it since they have complete control over a 2003 pcm. Tha part that saddens me was I wasn't able to tame it with the current mods. Before the swap from what I gather we were good to go. Then the swap added a little mix up to the game and the lack of control limited me.
Old 05-27-2015, 08:30 PM   #9
Haha, I'm not letting you off the hook. You did great on the first box until the manual reflash screwed up the air flow table. That was beyond your control. I'll get B&G to adjust the idle, speed and rpm limiter. Then we can finish with your tune. We just need to see how the box acts and what can be adjusted.
12.37 @ 111mph
Old 05-27-2015, 08:36 PM   #10
Oh ok yippie lets do this! There is deff a learning curve once you run a big cam that needs idle raised in order to tune it. 2003 trucks have there limitations but once done we will know exactly what needs to be done to run any cam in a 2003.
« Lifter Replacement | - »
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
