New Trans Codes - Hemi Truck Club
Old 05-14-2016, 02:27 PM   #1
Enormous Member
Hugh Jassole's Avatar
New Trans Codes
Ok, tranny acted up again today. last time this happened I was told the trans lost its adaptives. A reset & quick learn put me back in business. Same symptoms today. Here's the codes
0700
0734
advanced trans code 34 & 56
Any clues ?
My other truck is an R/T
Old 05-14-2016, 02:44 PM   #2
That 734 is no bueno
Old 05-14-2016, 02:50 PM   #3
Tyler
TYSENUS's Avatar
The P0700 is just a mil to say that there is a stored TCM code. The other says gear ratio error in 4th. It sounds like it usually indicates a variation between the input and output speed sensors. I would recommend checking to make sure that they are reading correctly. Note the input will read half the RPM as the output.
You never made any mention as to if you had felt any slippage while driving. If you lost 4th gear, like I did two weeks ago, and had slipped it enough where the input and output rpm signals varied enough to trigger the P0734 code then it would be time to order some clutches.
Mods:
Old 05-14-2016, 03:00 PM   #4
Tyler
TYSENUS's Avatar
I should have actually phrased it that the code does reference a variation in the input/output signals, it just depends on what is causing the variation. With the Red Eagle frictions I'm running, there was no material in the pan and no discoloration or burnt smell with the trans fluid. We literally had the trans out before we figured out the cause. Good luck!
Mods:
Old 05-14-2016, 03:48 PM   #5
A scanner and a CVI count normally will show you of its clutches that are worn out. That 734 code is deff bad news though.
"CMR TUNER" 11.63@115.87 1/4 with a 7.32 1/8 custom long/short bars by "Me" Turbocharged 392 on 12psi S475/96/1.32 . Running thru an A518!
Old 05-14-2016, 04:05 PM   #6
Enormous Member
I did lose OD, but a quick restart brought it right back. The throttle also doesn't respond to input @ times. Restart cures that too.
Old 05-14-2016, 04:08 PM   #7
Enormous Member
yeah, the 0734 has me worried too. When the trans took a shiz last year, 0734 was one of the codes. Who is the vendor who is selling the beefed 545s ? Mine has some upgrades, but nothing huge
Old 05-14-2016, 04:42 PM   #8
Enormous Member
Is the Sharadon Stage 3 a reliable way to fix this for good ? 1800-2200 every year sucks. I'll pop the 3Gs, but I want to know that I'll be done with this area of the truck
Old 05-14-2016, 05:54 PM   #9
A guarantee, I wish you luck with that on a modified truck. Try reading the Arrington statement on the reliability of a 545RFE...
2003 RCSB, 2wd, Street Truck
6.4L/cog driven V7-Ysi/46rh trans/Armed-HTH
11.66@117.61mph 60'@1.72
Old 05-14-2016, 07:00 PM   #10
I have had good luck with mine but I also do absolutely no highway passing. I also do no highway on ramp accel. I punch it from a dig only or manually in 2nd and shift to third I do not ever go into 4th gear at wot.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
