late 2004-2008/9 custom efi AN setup - Hemi Truck Club
Old 09-02-2012, 10:07 PM   #1
ok here goes nothing this is a fuel setup i did on my truck for roughly $200-300 less than what it would have costed me to do if I was using billet rails which in my personal opinion are a waist of time them are really just for looks most aftermarket rails are 5/8 diameter measure the factory ones guess what there the same on our trucks only real diff is the opening going into the injector but it doesnt matter anyway beacause the hole in the bung is the same size as the back of the injector where fuel enters so opted to go with a little modification of my own and it works great this setup i am going to show you is on a S/C 392 hemi with a stage 3 sharadon trans 3500 edge convetor and 456 gears needless to say it badass and needs alot of gas well this is what i did to solve the issue
"CMR TUNER" 11.63@115.87 1/4 with a 7.32 1/8 custom long/short bars by "Me" Turbocharged 392 on 12psi S475/96/1.32 . Running thru an A518!
Old 09-02-2012, 10:20 PM   #2
parts you will need for this build it is completly custom from pump forward and back to tank
1 walbro 400lph fuel pump (high hp app)255lph most others
1 efi fuel pressure regulator
25" of -6 an fuel line
12" piece of 3/8 tube
Another set of factory fuel rails(junkyard will work)
1 piece of 5/16 factory plastic push lock hose(autoparts store)
1 efi 10 micron inline fuel filter 9" long jegs
9 -6 hose ends
1 -6 end-3/8 tube compression fitting
1 -6 regulator plug
2 -6 radiused regulator fittings
2 -6 90* hose ends
2 -6 tees with swivel on side
2 3/8 quick connect to -6 male fittings
2 -6 90* bulk head fittings with nut/grommet
2 -8 female-6male reducers
tools need
elctrical tape for wrapping line to be cut
90* grinder thin cutting wheel
drill with large stepper bit
hammer and a cold chisel
11/16 wrench
3/4 wrench
9/16 wrench
22mm wrench
3/4 socket
3/8 wratchet
10mm wrench and socket for factory rails bolts
15mm wrench and deep socket for tank starps
boiling water
3/8 dissconnect tool
razor blade
dremmel with sander
jb quick
Old 09-02-2012, 10:25 PM   #3
to start it off remove air intake tube exposing spark plug wire assembly 2004-late2005. 2006 up has coils remove plug wire assembly and set asside now unhook throttle connector all injector plugs and unclip factory harness from intake and move aside should look like this about now
Old 09-02-2012, 10:28 PM   #4
next remove the bolts holding the rail in place 4 of them dissconnect the 3/8 factory fuel line and carefully pull up rail by lifting at ends and wiggling at same time can be stubborn and not want to come out but it will show it whos boss once out you will notice the there is a quick connect on one side and a threaded end on the other we need to change that take the razor blade and carefully cut the grey tube off the factory rail on both side leaving you with two rails unconnected. now do the same to the second set of rails and set asside both rails with the threaded nipple on them they are not needed anymore.
Old 09-02-2012, 10:36 PM   #5
next take the two rails you still have with the 3/8 quickconnect stlye ends to your pot of boiling water with the 5/16 fuel section set one end it hot water for about 30 secs and then quickly push it onto the barbed nipple in the center of one rail and then to the same to the other rail making sure the have both rails parallel to one another and when done should look like this
Old 09-02-2012, 10:37 PM   #6
reinstall injectors and put new assembly back on the truck
Old 09-02-2012, 10:42 PM   #7
now comes the fun stuff get the rear of the truck in the air i used drive up ramps and backed up them giving me just enough room on my lowered truck to slide tank out rear end without issues
once up dissconnect filler and vent line loosen the 15mm nuts holding tank straps tight (hopefully tank is mostly empty) and lower tank 1/2 way disconnect fuel pump/sender connector evap main line and fuel feed line lower tank to the ground and slide out from under truck you get this
use the hammer and chissel (tools available at time) and hit the ring counterclockwise to remove pump
Old 09-02-2012, 10:50 PM   #8
with pump and sender assembly out dissconnect the pump plug and cut the connector of flush cut fuel lines and remove the pump from basket. snap two lock tabs off inside of top cover and twist off the factory regulator/filter assembly and throw it all away now you should have a module the has a 3/8 nipple sticking down to an empty fuel basket in order for the 400lph pump to fit you will have to snap off 2 of the 3 pump reatainers shown with screw driver
Old 09-02-2012, 10:55 PM   #9
now flip it back over and useing a razor blade firmly press down on the fuel feed nipple while slowly cutting at plastic it will eventually just snap off you wont actually cut thru the plastic with the blade its just to cause a stress point it should be flush now
Old 09-02-2012, 10:58 PM   #10
next take your dremmell tool and smooth out the ribs right in front of the nipple you just cut off this is where your new feed line fitting will go
use some jb quick and cover the factory hole in wont be needing that one anymore
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
