Annoying air leak - Hemi Truck Club
Old 09-22-2017, 03:52 PM   #1
Truck of the year 2014
Belgiquebasterd's Avatar
Annoying air leak
Driver side door window is leaking air and making an annoying noise when driving. As you can see in the pic, the seal on top isn't fully closed. Any way to adjust this?
Old 09-25-2017, 09:54 AM   #2
Enormous Member
Hugh Jassole's Avatar
adjusting the track inside the door should enable you to tilt the glass in a bit further
My other truck is an R/T
Old 09-25-2017, 08:14 PM   #3
CavRam's Avatar
Cannot see the picture here. Is the seal intact? Is the seal compressed?
Or is it just not seating all the way to the door jam?
First two questions would call for replacing the seal. Third would be either adjust the door hinges, or do what I did on my 04 and roll down the window and hold the door with one hand and pull the top of the door above the window opening with a few forceful tugs to remind it where it's suppose to be.
2014 Ram 1500 Express
Old 09-26-2017, 08:59 AM   #4
I'm hesitant to mention the last technique is sorta what I used, except i wedged a block of wood at the bottom and pushed at the top. Lol
2003 RCSB, 2wd, Street Truck
6.4L/SuperCharged/46RH trans/Armed-HTH
11.66@117.61mph 60'@1.72
Tuned by Charged392
Old 09-26-2017, 02:00 PM   #5
Exclamation
I've seen 'professional' body shops...do the same thing .
Old 09-26-2017, 02:04 PM   #6
Sorry for the pic guys, still recovering from the photobucket debacle :-) I'll try again, the way i see it is that the window is maybe tilted forward a little bit, how can I adjust this?
Let me know if this works :-)
Old 09-26-2017, 04:52 PM   #7
Weird issue there you can try adjusting the tracks in the door but may not work. Make sure the window mounts to the regulator are fully on the glass and not coming off also
"CMR TUNER" 11.63@115.87 1/4 with a 7.32 1/8 custom long/short bars by "Me" Supercharged 392 on 15psi YSI-V7. Running thru an A518!
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
