Trans issues - Hemi Truck Club
Old 02-13-2017, 03:57 AM   #1
Trans issues
Don't know if this is an issue with the trans or something else that I'm overlooking but wanted to see if anybody has had the same problems. I have a 2015 2500 hemi (of course) and the issue I have is when start off from a stop it acts like I have bad gas, in a steady acceleration it feels like it's slipping in the first couple of gears and you can hear the tone in the exhaust change. Another thing it does is on cool or cold mornings it takes a while to go into o/d. I bought this truck used with less than 30k and now it has 39k. Just want to see if this is common. Sorry if this doesn't make sense, I'm rushing to get it wrote before work
Clintbo2000 is offline   Reply With Quote
Old 02-13-2017, 04:17 AM   #2
The OD shift when cold thing is normal as it's trying to build heat in the fluid as fast as possible. As for the odd feel taking of that's something to look into. Is this only when taking off or can you get it to do it around cruise speed when trying to lightly accelerate too.
"CMR TUNER" 11.63@115.87 1/4 with a 7.32 1/8 custom long/short bars by "Me" Turbocharged 392 on 12psi S475/96/1.32 . Running thru an A518!
Old 02-13-2017, 05:33 AM   #3
The time it's noticeable is start off, also it acts up when slowing down to turn and getting back in the throttle it'll act like it's hesitant about going and then just go. Don't know if this is another issue but whole on cruise I can have it set at 75 and it doesn't matter flat road or hill, it will lose 3 or maybe 5 mph and then catch back up usually causing it to drop a gear to do it. I guess I should also add that it's lifted on 37" but has been calibrated.
Old 02-13-2017, 06:25 AM   #4
Ok may be an issue in the trans do you have access to a scanner at all to get cvi numbers?
Old 02-13-2017, 07:07 AM   #5
My brother has a scanner but I'm not sure if it'll read those, I'm taking it to the dealership Wednesday for a radio problem, I'll have them pull it if they will. I've let them check it out before but of course the tech said it didn't actually up with him, and they won't let them ride with me to let them witness it
Old 02-13-2017, 08:32 AM   #6
I hate dealers but see what they say anyway
Old 02-13-2017, 08:45 AM   #7
Make sure you remove your tuner before going the dealer or you'll likely end up with it needing be reset.
2003 RCSB, 2wd, Street Truck
6.4L/cog driven V7-Ysi/46rh trans/Armed-HTH
11.66@117.61mph 60'@1.72
Old 02-13-2017, 09:45 AM   #8
It's not a tuner, the dealership I purchased the truck from just got a speedo calibrator for it after I fought with them for months telling them that I needed a tuner due to the 15 models needing a new or used ecu in order to change stuff to adjust for tires but I found out from somebody else that you could do a speedo calibrator but if I wanted to do a tune I would have to buy the diablo kit with ecu and tuner and that is around $1000, so the dealership got out of buying that for me.
Old 02-13-2017, 05:18 PM   #9
Ghost03hemi's Avatar
Have you changed your gear ratio to match the new size of the tires yet? When was the last time the TB was cleaned? Get a Diablo tuner to calibrate for the wheels and use the 92 octane tune.
03 QCSB, 5752lbs, 03 PCM, Turbo, 5.7, KRC Tune
12.79@103mph, "Full Street Trim" & tow hitch.
https://www.youtube.com/watch?v=RQ72xXx5dck
Old 02-13-2017, 05:45 PM   #10
No gear change, I bought the truck like it is so I assumed it was good to go. I didn't notice it doing this when I first purchased it because it had factory exhaust, it's really noticeable with duals so that's why it became an issue. It did the cruise part issue from the beginning. I want a diablo tuner but right now I'm going through a separation from my wife so funds are very limited- anybody want to donate one just let me know
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
